Banks has nothing to gain from it, he doesn't sell differential covers...So banks does the test and they win.
Suprise Suprise.
Suprise Suprise.
He brings up some good points and its a very well thought out test from an engineering standpoint. Something I never thought of was the fact that there may be little to no moving air on the backside of the differential, making the fins on the cover about useless.
I was surprised the temps. I had no idea the diff gets that hot.
That looks like the best design. Can you find one to fit my GMC Dually??This is a factory ford, my dad's superduty had this right from the factory.
View attachment 684199 View attachment 684200
Aluminum diff cover? I'll save my cash for a pair of truck nutz
Stamped steel covers dent instead of break when a rock hits them.....one thing to think about
LS engines have an aluminum oil panWell don't hit them with a rock. duh.
You know that many oil pans are made from aluminum now, right?
Yea, do they hang low at the rear of the vehicle below the axle though? NoWell don't hit them with a rock. duh.
Low enough, I had a 91 mustang with a 2.3l 4cyl and it had an aluminum pan on it and a rock hit it and cracked it, but I have never been driving down the street and drive ba a rock and have it chase me down and dent the diff cover on the back of my differential LOL.Yea, do they hang low at the rear of the vehicle below the axle though? No
What freeway do you drive on?Aluminum diff cover? I'll save my cash for a pair of truck nutz
Wrong, they do sell diff covers.
LOL
You have a link to show that? I’ve never seen Banks advertise any diff covers, even other brands.
Since when does the diff cover hang below the axle?Yea, do they hang low at the rear of the vehicle below the axle though? No
100% agree. There is a benefit, it’ll be interesting to see how much. I have a finned aluminum cover (not square tho) on my F250, hopefully it’s doing something lol.The cooling fins and the fact that the cover is made out of aluminium will help reduce temps just because of the metal and radiation even without airflow as you have added surface area to dissipate the heat.
Draw a centerline thru the axle housing....where does the bottom of that big ass aluminum finned diff cover sit?Since when does the diff cover hang below the axle?
Just sayin.
YesWhat freeway do you drive on?
Are you training for Koh? Lmao
Sent from my FRD-L14 using Tapatalk
Hint - it isn't above the axle tubes
Well... there is a benefit to having more fluid.
Some differentials do not have a removable rear cover that can be replaced.
EDIT: The Ford 8 and 9 inch rear ends do not have a removable rear cover if memory serves me correctly.
You guys can’t really believe Gale made these vids out of the goodness of his heart...
He’s angling to show shortcomings among the competition, then his product will address these shortcomings.
This is marketing 101...
LOLI think I see the first part of your problem lol
[emoji1]
Oh I agree!You guys can’t really believe Gale made these vids out of the goodness of his heart...
Technically speaking, you are correct. Hint, however if you cut down the exact centerline, you don't have an axle sir.
Brian
When I worked in the diesel field, we sold Mag-Hytec pans and covers. Increased capacity is the main benefit...more oil = longer time to get to critical temps. The diff covers also have a dip stick/fill and a drain, which means you don't break the seal (and make a mess) pulling them off the axle housing to change fluid. The fins probably don't do much in the way of actual cooling, but more surface area is more surface area for dissipating heat.
The banjo would be early ford closed drivelines with bolt on axle tubes. The name comes from the side view of the center section. Unfortunately, the clock and table I'm building are the only two pics of these I have on the phone.Dodge 8-3/4 is a "banjo" housing as well.
Yes they do, and I’ve never heard them called that. The one I posted above is the only type of rear I’ve ever heard referred to as banjo.Ford and Dodge both have drop out center section gearsets called pumpkins, as far as I know the housings were called banjo housings.
Most famously, the Dodge 8-3/4 and Ford 9".
