Altitude Adjustment Question
shueman
#141
I'm running an older 90hp Yamaha carb'd 2-stroke. We're headed to the Sierras next month for a few days and the lake is at 5500'.
I've been up around 4000' with no issues. Can't find my service manual so I thought I ask the o/b guru's on RDP.:thumbsup
Anything I can adjust to add air to the mixture (if needed)...?
SloWhacker
I ran my carbed 200 Blk Max at Huntington (7000 ft) with no adjustments for yrs.Ran awesome.I just propped down when skiing.You will be fine.Should any issues arise,see Sheldon@ Sierrra Marina.Excellent mechanic.Youre gonna have a great time.I cant remember when Shaver was this full.:)
Any pics?? I've never been there, but the pics I've seen have been awesome.
SloWhacker
It sux up here.....:)
I have more i will post after i find them........:grumble:
shueman
#141
Thanks...:thumbsup Despite it's age, the motor is like new inside...perfect for puttin' around looking for fish...;) Leaving this coming Sunday...
Luv2gofast
Ski at Huntingon:bowdown: I did it once...tooooo cold for me!
Outnumbered
Don't tax me bro!
is it oil injected or premix?
Faceaz
It would. Injected engines won't load up as much at idle. As an example, some of the old OMC VRO set-ups lean out to nearly 100:1 with no load @ idle, then go to 50:1 when the engine is put under load. Premixing @ a constant 50:1 will tend to load it up a bit more because the engine can't cut back the oil with reduced load.
I never liked the VRO because it's mixing before it gets to the float bowls, so if you get on the gas from idle, there's a little lag time before the engine will adjust to 50:1. Then again, I just grenaded our motor a few weeks ago, so WTF do I know.. LOL...
SloWhacker
I have also ran a pre mix 200 up here with no adjustments and no issues.:cool: Sorry bout your motor.:(
BajaMike
If the motor has an air filter, make sure its clean or put in a new one. Also, I would buy a lower pitched, aluminum prop just in case you need to prop down.
shueman
#141
Thanks for the input y'all...:thumbsup Just had to postpone the trip due to some issues with the wife's work...:( Rental company was very understanding and will honor our reservations in Sept...:cool:
