Groper
- May 6, 2009
- 2,219
- 1,873
Well this Bronco isn't even close to RB's & Dezrider Bronco's but should be fun to drive.
I was about to purchase a Bronco in either stock form or a partially built Bronco to do a FULL build BUT after talking to a few shops and getting into a Q for a build was more than 6mos out and then of coarse the build time that will extend way past the scheduled estimate.
So after some horse trading I ended up a Bronco that doesn't need anything the previous owner(s) pretty much did everything I would have done if I were to build one from scratch.
Immediate plans are to paint match rear fenders, two tone paint (Gray) midsection down the side like the factory looked, Powder Coat front and rear bumpers gunmetal gray. Replace the carpet with a rubber floor.
Pipe dream, fabricate a new dash, console, gauges re-wire and maybe some HP.
1990 Bronco XLT trim w/92-96 front clip
Full Caged front to rear all tied in together and Rhino Lined.
Mastercraft seats with rear bench
Mastercraft 5pt harnesses
Lowrance GPS
Roadmaster radio w/ PCI int.
Safecraft Firesuppression system
Autofab hood
Fiberworks fenders
BD XL80 Leds
17" Method Beadlocks
FORD 351 Windsor crate motor
e4OD built with billet Torque conv with Art Carr shifter
Short tube headers
Canton alum. rad catch can
CBR large trans cooler w/fan
PML High Cap trans oil pan
Autofab eng & trans mounts
Slip yoke driveshaft
Front Suspension (new)
Ohhcho Fab 4.5" over trussed I-beams
Ohhcho Fab single swing steering with double sheared spindles and pitman arm
Warn Locking Hubs
Currie Axles
Yukon Gears 4:88
Fox 2.5" C/o's
Fox 2.5 Triple Bypass
Fox 2.0 Bumps
Howe Ram assist with PSC res.
Hollander Fab w/ 14" rotors
Wilwood calipers
Rear Suspension (new)
Currie F9 Full Floater 9" w/disk brakes
Yukon Gears 4:88
Spool
Currie Axles
BMS skid Plate
Deaver Q80 Leaf's
4130 Extended Shackles & Hangers
Fox 3.0 Triple Bypass
Bilstein Air Bumps
Lowrance GPS
Autofab hood
Fiberworks fenders
BD XL80 Leds
Short tube headers
Warn Locking Hubs
Currie Axles
Yukon Gears 4:88
Fox 2.5" C/o's
Fox 2.0 Bumps
Wilwood calipers
Yukon Gears 4:88
Spool
Currie Axles
BMS skid Plate
Deaver Q80 Leaf's
Bilstein Air Bumps
