Echo Lodge
- Aug 27, 2009
- 3,447
- 5,426
I have a 93 YJ with a rear Dana 35 C that is leaking dif oil. The Yoke seal is probably original with 91k miles on it. It is NOT leaking around the yoke shaft. Dif oil is coming out around the yoke nut. I have ordered a GENUINE OEM SPICER DANA 35 REAR PINION NUT SEAL CRUSH SLEEVE JEEP XJ MJ ZJ YJ TJ. My question is does the crush washer seal the dif oil from coming out of the yoke? I have read that putting RTV on the splines of the yoke will stop the dif oil from wicking past the splines and through the Yoke nut.
I have wiped off the oil from the yoke in the pics but its definitely coming from the yoke nut. The dif oil is getting thrown from the yoke all over the undercarriage.
