spectra3279
Vaginamoney broke
- May 17, 2011
- 16,610
- 17,350
Get these?
I think so. Its for my trim tabswhat is that? 7/16" Inverted flair to -4 AN JIC?
If i was still in komifornia I would go see brooks. Fucker is a friend of minenot sure of your area, but try Mesa Hose in costa mesa. talk to brooks.
So what ould you charge me for 4 of them? Plus mailing to ky.That’s for sure a silver soldiered part. It was made because there are very few 90deg inverted flare hose ends. We have them at times.
We silver soldier lots of fixes for folks.
That is for hose ends im wanting the threaded on both ends. And its 3/16Gates # 4C14-4MIX90
Call some local Gates dealers
Those fittings.4 of those? Or 4 hoses?
Let me get home and ill measure to make sureOk, I’m at an outlying store today. I’ll be back at the big location tomorrow.
I’ll work on it and PM you.
3/16 inverted flare x 4MJIC, correct?
Here are the measurements
That was my exact thought. They look like someone cut the swept ends off a merc hose kit and silver soldered to a stainless -4 AN nipple
ThanksAnd that is exactly what I’m going to fab for him. [emoji106]
Thanks
This is the last parts I need for the boat. Just in time for the end of the season
What brand/Model trim tab?I think so. Its for my trim tabs
Yep. They are mercruiser. I think they are 280'sWhat brand/Model trim tab?
If it's a Mercruiser tab, do you happen to have the serial number too?
Usually the serial number is found around the tab area.
As you've pointed out (and know) it sounds like you have a custom designed setup to where all OE parts might not be easily found in certain situations like this as looking over the trim tab parts guide of common models listed, it mostly shows longer hose kits vs smaller fittings like you have... With using the model type or serial number in the Merc parts guide, I figured I'd just give it a shot for you to see if maybe there could of been a second alternative if ever needed.Yep. They are mercruiser. I think they are 280's
The rams are from my onl ones and nobody knows what they were. The rams are actually old outboard trim rams.
Thanks. And yes he is pretty cool about it.. But that is one of the good things about this site.As you've pointed out (and know) it sounds like you have a custom designed setup to where all OE parts might not be easily found in certain situations like this as looking over the trim tab parts guide of common models listed, it mostly shows longer hose kits vs smaller fittings like you have... With using the model type or serial number in the Merc parts guide, I figured I'd just give it a shot for you to see if maybe there could of been a second alternative if ever needed.
Trim / Tilt / Lift Systems and Components - 1994 & Up
Trim / Tilt / Lift Systems and Components - 1994 & Upwww.mercruiserparts.comTrim / Tilt / Lift Systems and Components
Trim / Tilt / Lift Systems and Componentswww.mercruiserparts.com
Pretty cool of [U]nganga[/U] to help get you sorted out though. [emoji106]
Good luck.
Can't make it kathy has dr. Appointment I have to take her toClark, have you tried James at Royal Brass here by my house. Come by around noon and we can go for lunch. Give me a call. Gary
That works for me if its not to much trouble for youOK, here's what I can do. I have the parts shown. I do not have the SS #4 weld fittings. I can get them out of So Cal in a couple days.
I could UPS them to you by Weds-Thurs for 22.00 each plus some UPS. I couldn't figure out how to PM a photo. I would cut them right above the top bead, silver soldier to the #4 MJIC.
Let me know.
Make 2.I need to make sure I have all required parts in SS. I’ll ping ya tomorrow
Thanks. Need 4 of them.It is no trouble at all.
Thanks. Just let me know price and I'll PayPal or venmo or whatever works for youGot it. I have all the parts, going to attempt to get the fab work done today. Ship either today or Thursday at the latest.
Nganga, thanks man thats another reason this site is so good.
