rivergames
- Jan 7, 2008
- 15,850
- 13,082
Drives me nuts when tile companies overseas try and bring that metric bullshit to America. You want to work with Americans, speak Standard you summa bitch!
10mm is the clitoris of the socket setOnly the 10mm. It needs to be banned
.75"Metric is great, if it's only used for stuff that was originally designed in metric. Imperial/Standard/whatever is also great if you keep it where it belongs. When the lines cross is where everything gets stupid.
How thick is a piece of 3/4" plywood?
My 3/8 sockets identify as 10mm.10mm is the clitoris of the socket set
Drives me nuts when tile companies overseas try and bring that metric bullshit to America. You want to work with Americans, speak Standard you summa bitch! View attachment 846851
Even worse - WranglersI like metric stuff personally. I hate working on cars that have both, like mid 90’s Ferds.
Hate it with a passion...
Need a standard bolt? Coarse or fine thread? How long? What size? Done.
Need a metric bolt?? Ho Le Fuk....
A 10mm bolt could have four different thread pitches?
Yeah, F that. F metric.
Throw some low grade torx head bolts in the mix, rounded over by the previous owner
You know standard bolts have different thread pitches too......lol
Your nuts identify as stripped
I’m sure more than one engineer jumped from building back then.Yep. It actually started before that. I was working at Lincoln Mercury when they started putting metric fasteners on cars. Long azz time ago.
GM did it too...
Completely insane engineering.
There’s all the countries that use the metric system and then there’s the one that’s been to the moon.
GM did it too...
Nope, I can never find a 10mm...10mm is the clitoris of the socket set
Believe when Canada went metric there was an Air Canada flight which lost power at altitude. They successfully made a dead stick landing at an old air strip/race way. They had run out of fuel due to failed sensors, a miscalculation on the specific gravity of jet fuel and the switch to the metric system. Due to using the incorrect specific gravity the flight crew had mis-calculated the fuel on board in metric tons.
Didn’t we win the war?
Agree with your point...However, often wondered if a great deal of engineering, research and fabrication was done in metric system for the Gemini / Apollo program? Mention this due to the overwhelming scientific nature of the development. The world of science runs on metric.There’s all the countries that use the metric system and then there’s the one that’s been to the moon.
Yep2 kinds of countries, those who use metric and those who have walked on the moon. I know of shops that will charge a additional fee if they get prints in metric.
I always say, there's no metric fasteners on the moon.
[/QUOTE
How sure are you about that? Beginning with high school chemistry then on to physics we operated in the metric world. I’m comfortable with both systems. But, science and technology do utilize the metric system.
.06'.75"
Enough Said !
sure the shit not 3/4".....How thick is a piece of 3/4" plywood?
how about CG DF 2" x 4"....
I getcha tho....
PS.... if we didn't already learn the American Standard measurements...
f.ing metric system is sure easier to use ... 1/10th divides much easier than 1/16", 1/32", 1/64"
This is pure gold.
Im so going to use this to fuck with my british buddies!
UD
