Anyone into air guns?
Mikes56
i just ordered an air rifle to blast the crows that are shitting all over my backyard. I've owned lots or firearms, but this is my first airgun.
Xring01
I have some high end PCPs
FX and a Airforce..
.25 cal at 980 fos drops coyotes at 50 yds
Mikes56
I just got a Umarex Gauntlet in .177. I'm looking for a scope for it, any suggestions on which one to get?
Make sure nobody calls on you if you live in city. Discharging a firearm is a crime. I dropped one over a year ago. Its mate still shows up squakiin at me every now and then from same pole. As soon as I go to grab my pellet gun it takes off. Smart birds.
EBT531
Are you in AZ or CA? In AZ a pellet gun shouldn't qualify as a firearm by ARS definition "“Firearm” means any loaded or unloaded handgun, pistol, revolver, rifle, shotgun or other weapon that will expel, is designed to expel or may readily be converted to expel a projectile by the action of an explosive.  Firearm does not include a firearm in permanently inoperable condition."
CA. Years ago had the local PD show up and explain it. Now I act like a sniper when the crows show up.
Xring01
I am no expert on CA Gun Laws..
But a Pellet Gun, is not considered a Fire Arm... Will a local cop try to give you ticket yep... But if you fight it, You will win...
Because Fire Arms have very specific definitions, that eliminate Air Guns....
My neighbor used to be Riverside County Sheriff, (Now retired and moved to Texas), we debated this for months... In the beginning he was of the opinion Airguns in City Limits are illegal....
I convinced him otherwise...
Do you own research though....
stoker2001
FX and a Airforce..
I got first gen AF Talon SS in 22cal..PCPs are SO powerful and accurate these day but don't come cheap..The short barrel version can be stealthy quite for urban setting,you have to mod the moderator with felt discs and washers,otherwise they are REAL loud!mine is so quite I think the thud from pellet hitting target is louder then discharge..Crows are crazy smart and will hold a funeral procession if you drop one in the flock..one time I got two with single shot as they were both next to each other on powerline and from my angle they were inline:cool:
zx14
Just make sure it’s a airgun scope, recoil is the opposite direction. Glass can dislodge if using the wrong one.
stoker2001
Yes sir,very important with spring piston powerplant types whether they are break-barrel or side cocking.Pre charged Pneumatics don't apply here
Mikes56
Ok thanks guys. I'll call the place I bought it from and see what the say about a scope.
JUSTWANNARACE
I have the gamo swarm and really like it. I especially like the 10 round rotary clips so you're not reloading every shot. And the scope is pretty accurate for what it is.
Sent from my SM-G892A using Tapatalk
LowRiver2
Pyramid air has great deals
Nope
Air guns not illegal in Ca
Reason I have on e
If you’ve ever driven through La Habra Heights you’d know why I one one.
It
Gets fired more than my duty gun some months lol
77charger
I bought a daisy for a couple of rats i had around the house it did its job got them suckers.Was a 10 pump model all i know is the newer ones are junk compared to the ones i had as a kid.All plastic on the new one the old one as a kid had wood stock metal pump handle and felt better overall.What a difference from 82 to 2006.
As for newer ones id probably buy one of the gamos or similar those seem to be pretty strong.
77charger
The
Nope
Reason I have on e
It
Not related to air guns but watching Adam 12 thought you’d find this interesting
Mikes56
So I got the scope mounted and shot at some targets in my backyard. It was about 25 yards away and I'm not happy with the group I'm getting on the target. It's nothing close to what the manufacturer claims. I was using some old Crossman ammo at first, then I changed to what airgundepot.com recommended for the gun. The groups are better, but not even close to where they should be. Anyone got any ideas? Is the a better pellet for target shooting?
Old Texan
Honorary Warden #377 Emeritus - R.I.P.
The red plastic point and brass pellets are accurate, so if those are what you're shooting it probably is something else. I have a Winchester which is actually a Daisy and could never keep the scope sighted in, so I pulled it off and just use open sights. Easier for the backyard vermin I use it for anyway. Accurate with the open sights so not the gun or pellets.
My Gamo Bull Whisper has a better scope and haven't had an issue with it. Problem with the Gamo is the 1400 fps makes it loud drawing attention when I drop a critter.......
Mikes56
Thanks, I just ordered some Gamo Red Fire pellets from Amazon. They will be here tomorrow. Can you suggest any others? I've never owned an air rifle before.
Old Texan
Those and the Gamo brass hi-speed are what I use
Mikes56
The Gamo Red Fire pellets did the trick. The gun is really accurate now. I'm gong to buy some brass pellets to see if it can get any better.
johnnyC
make sure you close the barrel fully, sometimes they look closed and are actually slightly ajar . your groups will tighten up. the locking latch can be a little sloppy
Mikes56
It's a bolt action rifle
JUSTWANNARACE
My ol ladies cousin came down from spokane. Got the Gamo out and took his boy in the back yard and tought him how to shoot today. Good times
stoker2001
every diff airgun will like diff ammo,its trial and error.try getting a sampler kit from RWS or Beeman/crossmen also JSB exacts are good.they get expensive,but you pay for what you get..Also barrel gets dirty from lead deposits and what not causing accuracy to suffer.good cleaning kit is a must.the good ones will be a cable with needle type attachment that holds a cleaning patch,follow directions using solution on patch pulling patch thru barrel.After cleaning it can take a few rounds to "settle" then you should get better accuracy
