Anyone using a 5 Blade on a V-Bottom ?
Groper
Anyone using a 5 Blade on their v-Bottom (single engine app.)?
What are you experiencing ?
Too much Bow lift ?
Transom lift ?
Cavitation in turns ?
Stress on the Drive ?
Anyone anyone.................
DRIVE BYE
Hey Groper, one of my neighbors has a 24r and he runs a 5 blade on a high horsepower application.:thumbsup
Groper
Cool, I plan on trying a 5 Blade on my 24' Schiada with a 1000hp, hopefully next month when the motor/drive are completed.
Snprhed
The hydromotive P5-X looks like a solid unit. Typically as fast as a bravo in the threads Ive been reading with a better hole shot, less likelyhood of blowout across the board. It is what Im looking at doing
The P5-X is for bow lift
P5 is for transom lift
skav
Too much Bow lift ?
Transom lift ?
I run a Maximus on my 270. I like it better than a B1
HALLETT BOY
I have a Maximus that I run on my 270 Hallett step , top end is slightly lower than the bravo 4 blade , but mid-range
is way better . I had to cut the defuser ring off , and cut down the diameter . After the second reduction in diameter . I'm
going to Havasu in 2 weeks to try it .
The boost power schiada 24 (orange one) was running a 5 blade at the boat show.
Groper
The boat is almost ready for water, I will see if I can try both types
Thanks
Snprhed
I Really Like The Looks Of The P5X I Plan On Doing Some Mods To The Engine And Want to Wait Until IM Settled On That Before I Spend A Grand On A Prop
Groper
Im sure there are some guys on here that will let you try one before you drop some major coin on a prop.
