- Sep 13, 2007
- 126,511
- 165,408
Want a free flat bottom in your neck of the woods?
Short deck Mandella?
Sure looks like one to me . Nose is correct and from the back how the deck is joined to the hull and you can see the slight v in the hull .I don't think Mandella. I couldn't zoom in, but nose doesn't look right to me and I couldn't see the sides. Still very cool though.
PICS? Free?They also have two Baja bugs, a 66 convertible bug and a buggy of some sort..
That is a cornucopia of treasures. You have the VW tow bar as well.Left ya a voice mail.
Gimme a shout!
I’m in!
As long as the extension ladder and dog bed gets thrown in!
Same free or real cheapPICS? Free?
Do you know where they're located.Same free or real cheap
No RD needs to tell us.Do you know where they're located.
Wheres the bugsThey also have two Baja bugs, a 66 convertible bug and a buggy of some sort..
Right on, Dave! Get er done!!!Went out to see the boat in Vista this afternoon(10 minute drive).
It’s a Mandella.
The rigging in it is pretty stout for a ski boat.
Check out the stringer rails and vdrive mounting/braces.
Even the plates have stiffners across under the turn buckles.
There are are no holes in the transom for thru-hull exhaust.
Real nice steering as well.
Just not your standard ski boat rigging for the mid-sixties.
The engine in it is just set in there.
It appears to be a 390. Nothing special.
The boat is in real good shape best I can tell.
It’s been sitting along time.
Be interesting to get it hosed off.
Gonna take some time to get it out of the slot it’s in.
Also it’s sitting about 2 feet off the end of the trailer, so that’s gonna take some figuring before it can be moved. View attachment 1444964
Holy crap, I had to look twice I have a Mandella under a similar lean to carport only it’s blue. Any info on the bugs?
Yes a 10 deg Hallcraft same as my Mandella was originally rigged . Sent the V drive to Tom Bently and had it machined to use casale gears and put a whirlaway in it . Wanted to keep it original .… kind of an interesting old Flatty… Having a hard time telling what the V drive is by looking at it on my phone
… got a better look… Looks like a split case non-parallel shaft Hall Craft…
@Clank123 Did you happen to see the Baja bugs or the convertible or the buggy?
Unfortunately I am in Tucson, Az . I am already in the middle of a restoration of my fathers 69 Shortdeck . I will let Eddie know . He might be interested .Buggy is a Chenowith updated with some newer shocks. VW for power.
1 Baja bug complete with some nice parts.
Including a full cage.
Other bug less motor.
The fella there was pretty vague about the future of the cars.
Almost like he wanted to keep them.
Both Bajas were covered and I was getting the vibe he wanted me to look them over yesterday.
Maybe that’ll change next trip out there.
I’ll put an update with some pictures…hopefully.
There’s a lot of stuff in the shop.
Some of it interesting, most junk.
There was one shelf with 15 or so Bug doors stacked it a row.
Up on another shelf there was about the biggest chainsaw I’d ever seen…had to have at least an 8 foot blade on it.
As far as the boat goes…
It’s going to take a few hours of work to get it out of there.
A trailer and a Baja need to be moved along with miscellaneous junk.
Tires are flat on the trailer(single axel).
Boat needs to be moved 2 feet forward on the trailer.
Hitch is broken, but I think I can make it work to get back to Carlsbad on side streets.
One of the interesting things is the boat, except for the transom around the plate hardware, appears to have been prepped and shot with primer. Must have had an issue with the bow eye as all that area is repaired and there is no bow eye.
So the plan, if they can get everything moved, is to go get it on Saturday.
I really have no interest in restoring the boat at this time for myself.
I have restoration projects booked to keep me busy until at least this time next year.
Being passionate about these boats, I just can’t let it go to the dump.
If anyone following this wants it or knows someone that does, it yours.
@AzMandella this has your name all over it!!
If you want to come help pull it out Saturday come on down(you might need to buy my crew lunch and a few beers).
Too many old flatbottoms have been lost in situations like this…I can’t let it happen again.
Let me know!
But it sure is fun .I know how this works.
For $35,000 you will have a sweet $20,000 boat!
Yeah no problem.Unfortunately I am in Tucson, Az . I am already in the middle of a restoration of my fathers 69 Shortdeck . I will let Eddie know . He might be interested .
How much do you have to spend?Clank, what's a ballpark cost to bring one of these to fruition?
Anywhere between the cost of some unistrut brackets to bolt the engine to the stringers....a few gallons of oil (some down the spark plug holes, some in the pan, some in the V-drive), a battery and weekend, to $60K and a year of someone's time to make it shine like new.Clank, what's a ballpark cost to bring one of these to fruition?
It all depends how far ya wanna go!You would have to post an armed guard if it was a long decker
Appreciate that.KIller find! If you need help let me know, I am a little ways away but don't mind a road trip!
Agreed. Certainly the correct engine for the time period.@Clank123 happy to hear you're going to save it, and I hope it finds a new home.
That appears to be the original engine, or at least a period correct model. The big two bolt inertia driven engagement type starter was used on the 1958-1962 FE IIRC.
That's the route I took with my 427. It seemed sacrilegious to put braided hoses and those nasty red and blue anodized fittings on it..
It’s a 390 so plenty of power, plus it’s period correct.
Wiring and plumbing (I’d keep it old school with rubber lines and hose clamps.
… yep… All this… This is how I nursed my my Hallett flatty back with the 406 FE motor in it…That's the route I took with my 427. It seemed sacrilegious to put braided hoses and those nasty red and blue anodized fittings on it.
Vicky would kill me if I brought up bringing home another Mandella. The long (marathon) deck is killing us.maybe the Valentines would like to add it to their collection? haha
Lou (A1 canvas) has 2 twenty-footers), our oldest son has one (a shot deck- aka krazy kraut), Lou (senior) has the long (marathon) deck currently at Eddie's, and cousin Ken has Lou senior's original 1963 short deck.Vicky would kill me if I brought up bringing home another Mandella. The long (marathon) deck is killing us.
Go for it, you still have the advantage of being able to out run her. LolVicky would kill me if I brought up bringing home another Mandella. The long (marathon) deck is killing us.
Is the red/white one shown the one that was in the back of Lou's shop? Or another one you guys picked up?
Your much more of expert on Mandellas than I am, but for me, and all the boats I’ve scouted over the years, the splashed boats(Gaylords come to mind) don’t have the signature curved transom.It's a Mandella or a splash
