Ultra912
- Jun 2, 2015
- 616
- 655
My audio system on my new boat is quite a bit more complex than in my last boat. It has 2 large amps and two large batteries designated solely for the stereo system. It also appears to have a shutoff/gfi, or whatever you call em, just for the battery amps. Question: Wouldn't all the batteries be inline so they all would be charged by the motor alternator simultaneously? He told me he used two different trickle chargers, one for the boat battery and one for the audio system batteries. Is this necessary? I wouldn't think so if they're all inter connected/inline with each other.
Next: It has an Interstate charging device already mounted in the engine compartment but when plugged in it only shows a red light and the charger says that if the yellow or green light are not on that the battery is less than 3 amps and requires a full charge prior to using but the battery seems to be sufficiently charged as it turns on the boat. The device I'm referring to as a shutoff/gfi is the one that shuts everything off when the button is depressed and the little tab pops up. BTW, what is the proper name for that thing?
