headshothills
- Apr 11, 2011
- 1,412
- 474
So this isnt your standard B&M 420 Mega Blower. This blower was sent to Supercharger USA and completely overhauled internally. Bored and trued, converted to 3 Lobe Helix rotors, everything internally was replaced, Billet bearing retainers added, heat treated input shaft, etc... This conversion is 20% more efficient over the standard version, this thing packs air. If you are looking to boost to 5 psi, you can stick with 750 CFM, anything above that you will need to go bigger, this conversion will literally suck the fuel out of the boosters depending on which pulleys you run. I ended up having to order a 2nd set of new carbs because 750's wouldnt flow correctly for 10 PSI. The same pulley setup that produced 9ish PSI with 750's, produced 15psi with Nickerson 1025CFM...
This setup comes with intake manifold, SuperChiller, Blower, Throttle linkage, Wilson Carb spacers, 4 Pulleys(6.75, 6.3, 5.8, 5), 1 superchiller 16v belt, 2 8v belts for smaller pulley setup...
$4500
If someone wants the carbs and the blower setup, I'll knock off $500 and throw in the spark arrestor...
$4500
