Ba Ba Ba boooooost question for you guys
Zeppelin654
I have a 1975 hallett bubbledeck full stringer jet boat. I bought the boat last year and realized the engine was smoked. I decided to rebuild the engine myself. It is a blown bbc full solid roller deal on gasoline. 8:1 CR, 31 degrees timing, 93 octane, 8 lb boost, NO intercooler, Iron heads, 2 1/4" headers.
Previously it had 1:1 pulleys (41 tooth top and bottom) with a mild (about .550 lift) hydraulic flat tappet cam. Made 6 psi. Maybe 600 or so hp.
The new build specs are:
Machine work done by Andy Jensen at Jensen's Engine Tech
Cast case non stripped rotor 6-71 blower
SRP pistons (calculated 8:1 compression now)
Total Seal file fit rings (gapless 2nd ring) .033-.034 ring gap
Forged shotpeened rods
Scat forged balanced crank
Clevite bearings
Melling m77 oil pump
10 Qt dooley oil pan
Gen IV bbc block (now 472 cubic inch)
World Products Bill Jenkins 1-043C 119cc iron heads
Cometic Stainless MLS 5 layer .070 headgaskets
dual valve springs with dampers
Comp 1.7 ratio roller rockers
Comp .135 wall 3/8 pushrods
Crower solid roller lifters
Comp 11-771-8 solid roller cam (242, 248 .646, .653 110 lsa)
Blp 3 piece timing cover
Rollmaster torrington timing set
ARP EVERYTHING
MSD 6M-2L, MSD hvc 2 coil, and pro billet hei distributor (locked out, 31 degrees BTDC advanced timing)
Moroso Ultra 40 8.65 wires
NGK heat range 8 plugs
2.5% over pulleys (40 tooth 1/2 pitch upper and 41 tooth under)
Jomar Professional stud girdles
Basset 2 1/4" coated headers
Dooley air scoop
Two side mounted Holley 850 four barrel carbs with 78 jets (square)
Weiand carb adapter and intake manifold with burst panel
Holley 190 GPH billet mechanical fuel pump (7 psi) 1/2" lines
Main bearing clearance is .033
Rod bearing clearance is .028
crank endplay is .0045
cam endplay is .004
Ring end gap is .033-.034
472 cu. in.
7.97:1 comp ratio
VE: 74.4%
I had it dyno'd and it made:
741 hp and 693 torque at 31 degrees timing on 93 octane
727 hp and 682 torque at 28 degrees timing on 93 octane
^ both peaks were right at 5900 (hp) and 5300 (tq) and 8 LBS BOOST
It had a berk jc pump with bronze A impeller and diverter. Loader hung 3/8" below keel. On the water it ran a best of 79 gps mph with just me in it. Of course, I can't leaver anything alone. I had the pump rebuilt and added a split bowl, mini droop, inducer, stuffer, the works. Trimmed the loader to right around 1/16" below keel. Sorry for the long intro, but my MAIN QUESTION is related to the engine.
I want to increase boost and make more power I can. This is a lake boat ripper if you will. Not a drag boat, but I run it really hard all the time. I probably run it 20-40 minutes at a clip. All between 4000-6000 rpm. Never goes below 60 psi oil pressure with 20w-50 gp-1 synthetic blend driven racing oil. I DO NOT run it on 93 octane. I ran it all last summer and for the future on 100LL AV Gas (no mixing) Factoring in a compression ratio or 8:1, IRON heads, NO intercooler, and Av gas, how aggressive would you guys think I could go? ( am not going to intercool or switch to aluminum heads or go to a larger slower spinning blower anytime soon because I already blew a bunch of money on the build last year, the pump build this year and the new exhaust. Maybe later but definitely not now)
I made 8 psi with the 2.5% overdriven setup which put my effective compression ratio at 12.4 (the altitude I run the boat at is usually around 1100 above sea level which should take .15 off the final compression ratio which is nothing, but I wanted to mention it)
If I overdrive the blower 5%, I should see about 8.6 psi putting me at 12.7 effective CR
If I overdrive the blower 8%, I should see about 9.2 psi putting me at 13.0 effective CR
If I overdrive the blower 10%, I should see about 9.8 psi putting me at 13.4 effective CR
The new exhaust I had custom made, is a set of swept back shorty 2.5" primaries w/ super short collectors (I know those are probably too big, but I just did it thinking I can always use them later if I go bigger at some point). I figure these will lower the boost number a bit.
To finalize my question:
It ran on the dyno on 93 octane, 8 psi, 31 degrees timing. no detonation, no issues.
I put 20 hard hours on it over last summer running 100% Av Gas, 8 psi, 31 degrees timing. no detonation. no issues.
I already changed the jets to 81's (from 78's), and put the 10% pulley on the blower. This is 9.8 psi (maybe lower b/c of the bigger exhaust), 13.4 CR. Do you guys think Im playing with fire based on my 100 octane av gas and 28-30 degrees timing?? I was under the impression that if you increase one pound of boost, you need two more octane points. If it ran great on 93 pump gas at 8 lbs, I should need at most; 4 more octane points (97 octane). Right??? or am I crazy??? Do I need more jetting to pull that off?? lower than 30 degrees timing?? I appreciate all advice, information, real world results, opinions. Obviously you can't just say "oh yea, it'll be perfectly fine!" or "It will blow up with the first turn of the key!" but I cannot make up my mind. Thanks a lot fellas!!!
obnoxious001
Engine building character
That's a long story with quite a bit of information that isn't necessary, but first question is who selected that camshaft?
Next point is you probably should have gone ahead and tested with more boost while it was on the dyno. Depending on the condition of that little non stripped 6-71, turning it higher could result in more heat and no net power gain.
Since you did not elect to test other combinations on the dyno, proceed carefully, and backing off timing would be one way to try to make it more "safe". Are you good at reading plugs (and know the correct way, not just color)? Ground strap and fire ring are important indicators.
Do you still have the "A" impeller, and what RPM were you running?
Zeppelin654
The machine shop picked the cam. After doing more reading myself, I feel as if I should have gone with a larger lsa. I trusted his judgment even though he is not a strictly boat guy, he knows his stuff. I do wish I had tried more combos on the dyno for sure. And it’s not like I couldn’t take it back in and probably solve all my worries, however I was hoping to make a few educated guesses and proceed from there based on the results. I will need to learn to read plugs to a higher degree for sure. Lastly, I still have the aggressor mag bronze A and it would run 5600-5800. Trimming of the loader may increase rpm, but the tighter pump may bring the r’s back down. I am not sure as I do not even have the pump back from powder coat yet and it’s 20 degrees here in Pennsylvania. (Reason for the long winded overly informative post was to not leave anyone wondering about an aspect of my setup which could skew their conclusions)
obnoxious001
Yep,, 114 would have been a better choice, more lift and more duration as well.
obnoxious001
Personally, it would make sense to go back and baseline with the pump changes before touching the engine. As I said before, that blower may not make more power with more boost, as heat becomes a factor.
H8Plow
To make more power you will need more boost. The 6-71 is a bit small imop and if you spin it faster the intake discharge temps are going to go thru the roof.
That’s a positive displacement supercharger and it really does need an intercooler.
Zeppelin654
I do understand the heat issue. I can't find real results of intake temp differences based on blower speeds. I was told by TBS that the 6-71 doesn't start to become inefficient until about 7500 rpm blower speed. I don't turn over 57-5800 rpm in the boat (probably less now that the pump clearances were tightened up from .022 per side to .010 per side impeller-to-wear ring). at 10.5% O/D, the blower will be spinning 6400-6600. on 100 octane Av Gas, do you think the extra heat will still be a killer problem?
DaveH
why not install an inlet air temp sensor after the blower and know what you are dealing with instead of guessing?
Zeppelin654
Any other thoughts on this? Any other opinions or real world results? I was thinking of going 8% O/D and 9 lbs boost. Jetting up 5 sizes. 100% avgas. Won't the bigger exhaust help with flow and the 110 lsa keep cylinder pressures down?
Blackmagic94
I run an AEM methanol injection kit on my 6-71
Octane and intercooler in one setup. And you could run regular pump gas
468 cid
9.25:1 compression
Unknown cam
Gm hipo heads
6-71
-17% under drive
5-5.5 psi boost on gauge
91 octane
Aem meth dual nozzle
Holley Xp 650 dual carbs
8.5 power valves
Billet dizzy mech advance.
Black with light spring
Msd digital marine cdi
30 degree total timing
12 degree idle base timing
