River Runnin
- Jun 17, 2008
- 5,522
- 8,052
A friend fueled up there twice. He just got his boat running day before yesterday after draining 6 gallons of water out his tank! Just a heads-up buyer beware!
Thank you ethanol!
You need to do some research and rethink this post.Actually, ethanol helps with this problem as it will absorb water, mix with gasoline, and burn.
Contaminated fuel has nothing to do with ethanol
Actually it does not. The water doesnt homogonize with the fuel so the more water it absorbs (it will pull the moisture out of the air instead of just dealing with whatever may get spilled into it), the more water accumulates on the bottom of the fuel tank, a.k.a. where the fuel pick-ups are located. So, the ethanol will actually substantially increase the chances of the engine ingesting water instead of fuel.Actually, ethanol helps with this problem as it will absorb water, mix with gasoline, and burn.
Did you run the boat at all after doing the fill up?Bummer
Just filled my boat with non-ethanol 91 from Campbell cove mixed with Stabil 360 for winter storage
Yes, ethanol mixes with water much better than it mixes with gasoline, but it still mixes with both...to a point.
I never ran a water separator filter in my boat for the first 7 years I owned it. I used to always use ethanol gas and never had an issue. I started (for some reason) using ethanol free fuel about 3 years ago and 3 times now have had water in the tank. Not much, but enough to cause me to paddle back to the beach. I siphon out what I can, add a can of ethanol 91, and I'm back in business.
If ethanol was the problem, we would see considerably more issues on the road with cars and trucks....and we don't. The only issues I've ever heard of with water in the fuel are in boats...primarily marina fuel. Boats exposed to water, and so are marinas. Water and fuel handling is the problem, not the ethanol. (Ethanol causes plenty of other issues, but having 6 gallons of water in a tank's worth of fuel I don't think is one of them). The fuel transportation method or storage system was substandard if that much water was present.
There is a product called "HEET" which is methanol, and used as a water remover when added to a fuel tank. It mixes and burns....to a certain extent.
I added the separator about 3 years ago and haven't had an issue since. Mine has the clear bowl on the bottom and I do see some water on occasion, but I can drain it out through a valve and carry on. I'm still using non-ethanol fuel, because it's available. For years though...no problems using ethanol fuel with no water separator.I take it the water separator fuel filters haven't provided a solution for you ? Too much water ?
You dont get the effects on road cars and trucks cause they rarely sit for much time so the fuel doesnt have the time to seperate. Also, the road is a much drier environment they operate in as well. I agree that storage of the fuel is a large contributing factor as well though.Yes, ethanol mixes with water much better than it mixes with gasoline, but it still mixes with both...to a point.
That is not correct. Alcohol (ethanol) is very soluble in petroleum, this is why they use it as an additive. Alcohol does not mix with water, but it is extremely good at absorbing it (hygroscopic). This is where the problem with an alcohol/petroleum mixture rears it's head. When the alcohol has absorbed about 3 tsp/gallon of fuel it looses it's bond and falls out of suspension, ultimately congealing at the bottom of the tank.
LmaoI think your first mistake was getting gas at black meadow landing.
They say the shelf life of e10 is about 3 months, but I’ve been lucky up to a year so far. If you a driving every day, it’s no problem. The boats, bikes and toys suffer.Perhaps your tank, but not in any of mine, YET I hope
I've had mixed results. In my Edger, E10 smells like bad gas in less than a month. It still runs, but after 2 months, it stuck a valve. Whats strange is...I filled the edger out of a 1 gallon gas can....I didn't empty that gas can for about 3 months. Gas in the edger smelled bad, gas in the can smelled fine. In my chainsaw, the E10 is probably 3 years old, it still smells like gas and fires on the 2nd pull. In my boat, I've left half full tanks of E10 over the winter and it still smells like gas the next summer...and works fine. My Suzuki DRZ400 sat for about 5 weeks with gas in the tank and would start and run, but wouldn't idle. Changed the gas, everything is fine.
Storage is critical for E10 I believe.
I got bad fuel too View attachment 703777
Wow!
