FROGMAN524
- Mar 16, 2013
- 4,926
- 8,493
Seen this?
I believe they're from Brazil.Can anyone tell what language they're speaking? Sounded Slavic of some sort.
They speak Portuguese in Brazil. Usually sounds like a mix of Italian and Spanish.I believe they're from Brazil.
ThanksYes they are speaking Portuguese
It's always fine till it isn't.........
Maybe I'm alone here, but anytime I am trying to break my own speed records, I'd rather have witnesses outside of my vehicle. 100 in a bass boat seems a little risky to me. Not a boat engineer, but common sense tells me that's the equivalent of a rocket powered Fiat.
Do you think they used the trolling motor to get it back to shore
I dont understand all the shit comments here?
The dude in the htm was almost the subject of a similar video, and the comments are all positive about that guy?
Guy is pushing the boundaries and lived to tell about it. Hopefully he learns and moves forward.
I guess the replies to you will be; "well an HTM is designed to go fast?".
Yeah, I'm all for hot rodding. Without this shit, I would have nothing to watch on Youtube.
Don't get me wrong, you find a couple J2 rockets, I'll supply the Fiat...you machinist want everything gnat's ass...this may be more plumb bob and woodscrew, but funI dont understand all the shit comments here?
Im in, still.
Saw MrPump's HTM here on Skaha Lake a while ago when local guy had it, It seemed rock solid running full bore, if that's what you askingI guess the replies to you will be; "well an HTM is designed to go fast?".
Hmmmm. That 400 sure makes that bass boat scream. Over 100mph in a bass boat that appears to be overpowered. That boat was unstable above 80. He was "sawing" the steering wheel trying to keep it on the pad or level if it doesn't have a pad and blowout was bound to happen. Very dangerous. I'm not a speed whimp but I would never go that fast in bass boat not designed to go that fast.
In my defense, I have no issues with doing stupid stuff at high speeds. I am just not one to do so with passengers. I could probably promise you if I had a bass boat with a 400, I'd probably test it out too.
Yeah he needs a better Bass boat and nows his time to get it after throwing that one away.He needs the passenger to balance the boat so he can get every last mph out of it. Bass boats are designed to go fast but some are designed better than others. He needs an upgrade on the hull and a new pair of shorts.
that's what i was thinking seemed soft no worse than getting tossed of a tube boat is done they got luckyThat was the nicest 100mph crash I've ever seen
That seems a little fast for trolling.
As usual, the first post based on sound facts instead of conjunctured opinion is way down on post 27.It's a Nitro, 65-68 is doing good in a Nitro. Next time maybe he will step up to an Allison, Stroker, or Bullet.
I'd like to know how they felt the next day!Pretty amazing how well they did in a 100 mph wreck. I’ve wrecked a bunch of boats at speeds much less than that and it hurt like hell, knocked the wind out of me, cracked ribs, bruised lungs etc.
What's blowout?
Soooo, severe cavitation and then reloading?The water around the gearcase becomes significantly disturbed enough and the lower unit or prop basically loses grip on the water. That’s not that bad, what happens next is. When the prop blows out the hull speed slows enough for the prop to find clean water again, when they happens the hook up can be violent and the torque of the prop will toss the boat sideways ass first.
Too much prop out of the water causing sudden slowdown.What's blowout?
