Best water proofing for wood on boat interior
bocco
Hi all,
I'm going to be making some interior changes and will have to cut some new plywood pieces for the upholsterer. What's a good product to water proof the wood? Will Thompson's work?
Thanks
Gary
lenmann
Polyester resin thinned 10% with styrene so it soaks into the plywood and seals it. Don't buy the junk resin from home depot, you never know how old it is. Resin and harder have shelf lives. Go to TAP Plastics, West Marine or any of the online fiberglass supply houses to get the resin
bocco
Thanks I have a TAP plastics close by. So do I add hardener to the resin and then thin it?
lenmann
Prep all of the wood and get all your application stuff ready.
Then thin the resin first with the styrene, mixing thoroughly, then add hardener, mix and get after brushing it on.
Hi all,
Thanks
Gary
Great tips from lenmann
Try adding a surfacing agent into the mix to give that thick protective layer. You can get this product at any of your resin providers along with the mix ratios.
Heylam
The addition of surfacing agent will give you a hard sandable finish, but actually thins the mixture slightly as it is nothing more then styrene with a wax additive suspended in it.
bocco
Just got done with this. It came out good. Probably could have used a little more thinner but it still worked good. Poured the left over in a plastic jar and it got hard as a rock. What I put on the wood is taking longer to harden.
Thanks for the tips.
