cg818
- May 24, 2017
- 21
- 4
Happy Saturday guys!
I've got milkshake and this will be my first time trying to diagnose and fix the issue myself. Had the boat out last October and got her up to 98 mph, 6100 RPM, did not miss a beat and ran beautiful all weekend. Was going to list for sale and while going through found the milkshake. Hoping you guys can help guide me along with the next steps for diagnosing and repair.
Motor Info:
489 BBC, aluminum heads, superchiller, 8-71 blower, dual holley 750CFM carbs
Diagnosis so far:
1. pumped out oil and water (9.5 quarts)
2. replaced with 5 quarts cheap oreilly oil and 1 quart marvels mystery
3. Pulled plugs and checked compression
- Cylinder #1: made two readings on this as the extension for the tool probably has a leak. 140psi
- Cylinder #2: 150psi
- Cylinder #3: 165psi
- Cylinder #4: 150psi
- Cylinder #5: 170psi
- Cylinder #6: 140psi, plug looks corroded
- Cylinder #7: 140psi
- Cylinder #8: 140psi
4. I have attached pictures below so you can see the motor, test results, and what the plugs look like
Any and all help is greatly appreciated.
Thank you!
- Corey
Motor Info:
Diagnosis so far:
Thank you!
- Corey
