Boat Moving With Golf Cart
Hydroman55
Have no clue..thus the question.
Does a battery or gas powered golf cart have enough power to move a 26 foot cat in and out of the garage?
JayBreww
Flat surface? Yea, although tongue weights an issue. Leave the wheel jack down and drive slow.
It will kill the cart. I used to move my 22' boat with the wheel jack down. No way it would handle my 26'. Friend uses his cart for a single ski and it just cost 700 in damage to cart.
Hydroman55
Well it appears it’s a bad idea.
Thanks
DarkHorseRacing
I wouldn't. We killed a gas cart trying to use it to tow two Seadoo waverunners around the Springs on a tandem trailer. Wasn't even a boat. Now we don't bother with it and just use a vehicle.
Hydroman55
Understood.....Reason I asked, backing through the garage door is a bitch as my dually fenders block the view as I line up straight given a 10’ wide door.
No big deal just I just get out and verify the clearance.
J DUNN
Unknown Member
Good thing you added some details to the story or question.
I now see your problem, you need an F150. :)
Just kidding, totally love your set up. Super sick truck, I need that to tow my Mandella Flat, old school cool. And beautiful boat too!
outboard_256
what cart do you use to tow with? We killed a cart trying to move a 22 foot boat around. We moved it about 10 feet and the motor just died.
Hydroman55
No cart was thinking about picking one up but it’s clear not for moving a boat based on the feedback from everyone.
outboard_256
how far do you have to move it? Maybe one of those electric trailer dollys would work. That's what we ended up using.
Ragged Edge
Man in the Box
A friend uses an old golf cart to move his Howard 23' Offshore into the garage. So far no issues, the cart works fine even without the wheel jack down. He's only moving the boat 20 to 25 feet and it's mostly flat ground.
What about adding a Frt hitch - drive it right in the garage
paradise
Spooner
All depends on the motor and controller in the cart. All stock, especially with a newer AC cart won't work well. An older DC cart with a high torque motor and higher current controller will do fine. Brakes are an issue so go slow! :)
Hydroman55
On the money DLC ....Was going to look at the truck to understand how to hide a receiver on the front.
240Hallett
There’s a nice samurai in the for sale section that would make a nice yard goat for your fleet. Multiple other uses too...
Hydroman55
Curious how another $3,500 is a problem?? Nice display!!
You made me laugh...Man O Man I guess I am a cheap SOB
Curious how another $3,500 is a problem, just jealous - Nice coral!
DarkHorseRacing
Well you wont see much better if you used a golf cart. You'd be staring down the tunnel of the boat and it would block your view of the trailer fenders too.
Hydroman55
Good point same problem of being too wide in reverse.
You got a link for this Suzuki? Cant Find it in the classified
I might be a little late but here is the link To the Suzuki....
