Boating at 7000' Elevation
88Checkmate
I have a 25' Shockwave with a 500 EFI, most of my boating is at a lake that is at 7000' elevation, the engine runs fine except that I am only able to get about 4500 rpm's at WOT with a 24" bravo 1 prop. at Havasu I can run a 25" prop and get 5100 rpm's.
would changing out the throttle body to something like a Hardin 1000 cfm improve performance to get more air to the intake?
or any other suggestions?
Thanks
Done-it-again
Have you tried a 22 pitch prop? You should be able to get more RPM’s out of it.
mash on it
Beyond Hell Crew
At 7000 ft, your 500 is ~105 hp down.
So you can prop it down or add hp.
Elevation likes forced induction.
(More oxygen/air and fuel, more horsepower...)
A larger throttle body may give you 10 to 15 hp, but over a hundred horsepower is unrealistic.
Dan'l
wsuwrhr
The Masheenest
Yep,
Dual hairdryers, or a supercharger is the only thing to fix low 02 content. :)
Compressing air is the only way to add air that just isn't there at high altitude.
Brian
Dan'l
Trash
Thanks
You need to put a smaller pitch prop on it. I'd go down at least 2" in pitch.
