it wasn't fair but it was fun.
I'm gonna guess its more likely that it pulls slightly right so he has a little bit of left steering input which makes the cable closest to the camera become the "push" cable and go slack.Am I seeing things, like your pump moving enough for you steering cables to slack under power.
Thanks for sharing the journey, reminds me of the HotBoat days of tech and horsepower.
It's because I'm steering the boat a bit.Am I seeing things, like your pump moving enough for you steering cables to slack under power.
Haven't been in Havasu in months. RDP does interviews? I thought Dave just organized parades n shit now?I hear that you were in Havasu recently for test and tune. If so, where's the RDP interview?
He needs your endorsement for mayor of LHCHaven't been in Havasu in months. RDP does interviews? I thought Dave just organized parades n shit now?
The impeller is a size thing. It just needs to be matched to the rpm range that you plan on using it most at. The loader is a whole other can of worms.At the beginning of the vid, you hinted about messing with either loader or impeller. That was kind of a question I had, what type of loader setup does something like that run? Your boat comes out of the hole like a trans braked promod. Sounds real good too. Thanks for the video!
Boat 405 provided great insight in his post. As it pertains to Game Over..the issue I have is that the boat leaves hard and then two seconds into the run it feels like its being tugged backwards and then it surges forward. It's not porpoising, the boat isn't hopping up and down, and the engine rpm doesn't vary greatly during the run, it doesn't hit the rev limiter etc. On the data system I'm monitoring pressure coming into and out of the jet pump in several places. What I see there is that the inlet pressure builds to about 35 psi and then falls off. Bowl pressure builds and then falls. The most telling data I have seen so far is from a vacuum sensor mounted to the keel of the boat. As the boat leaves the line the vacuum increases and then right as the inlet pressure falls, so does the keel vacuum. The boat seems to be running out of water. To combat this, I've lowered the shoe several times in an effort to pick up more water. I began with the biting edge of the shoe about 1/4 inch above the keel and it is now 1/6-inch below the keel. Lowering the shoe has not increased the water pressure coming into the pump or made the boat run further down track before it runs out of water. I believe this is because I'm running a flat shoe and as I shim the shoe downward, the ride plate also is lowered in the water with the shoe. The boat ends up riding higher and higher every time I lower the shoe. It's my belief that the boat needs a tapered shoe, that can be shimmed downward without lowering the ride plate significantly. That will be the next part I test. I'd really like to go to a track but there are no races near me so I'll keep testing at my home lake until the boat actually works well enough to be competitive.I was hoping Cyclone was going to touch on it a little more in the video as far as hardware changes. I was guessing loader or he tried a different shoe.
Drag boat racing needs all the help it can get in terms of growth so I'll tell anyone anything about my boat, motor etc if it will help them get their boat on the water.Hardware setups are a bit sacred. If you’re going racing it’s not something you want to go out of your way to advertise. Sort of like the family holiday dish and recipe.
off the top of my head I'm monitoring:I'm impressed at the amount of data logging points/sensors you have on game over. (Hull vacuum, hooda thunk?) NASA would be impressed...
Dan'l
Pretty much any type of boat racing needs help sadly. Loved the youtube vids on the progression of the boat,,,,come a long way and turned out awesome.Drag boat racing needs all the help it can get in terms of growth so I'll tell anyone anything about my boat, motor etc if it will help them get their boat on the water.
Lmao,,,,I still say a built turbo ski would be a great race . The amount of untapped HP in a 1.8 SVHO Yamaha motor is borderline criminal.
Lmao....there is no way to describe it in words to someone. Only thing close to it would be if you ever launched a pro stock or pro mod drag bike....your hanging on for dear life while paying attention to everything else necessary to not get tossed off like a lawn dart. And like drag bikes you can quickly mod the usefulness and overall ride ability of the ski straight out the window. There is a learning curve when going from stock to a 350+hp ski and you can potentially kill one of your novice riding buddy's if not careful before letting them take it for a spin. Totally been a fun new distraction for my HP A,D,D, as my wife calls it,. Hey it's keeping me from buying new different cleavers to test on my OL, The look on the wife's face when she heard it for the first time after mods was priceless.(rear exit open water box exhaust that wakes the dead in near by states) and I pretty much knew I was in deep shit but totally worth every penny spent so far in my book PLZ Keep me posted on how things go with your buddy, The 310r Kaw is a bad ass ski.Buddy out here in Missouri has a Kawasaki and he is turning it up to 23 pounds of boost this year....it is fuckin insane to watch him launch!
