Bolt cutting jig
Discussion in 'RD's Lounge' started by lbhsbz, Jun 14, 2019 at 8:57 PM.
  1. lbhsbz
    lbhsbz Well-Known Member
    3,192
    4,584
    Jan 11, 2010
    Thought I’d share this. I originally made this to cut round things under 5/8” on the band saw. As soon as the stock spins, it tends to take teeth off the blade. I needed a fast way to hold things steady, repeatable length was a plus, and without damaging the workpiece.
    This thing kicks ass.
    When I’m working on a project boat...I never know what length bolts I’ll need because I can’t guess the thickness of the glass. I like minimum thread protrusion.
    I typically order boxes of the longest fully threaded fasteners In each diameter I need, then chop ‘em down to size instead of ordering 10 boxes of different lengths.
  2. wsuwrhr
    wsuwrhr The Masheenest
    37,047
    24,301
    Dec 20, 2007
    "Uncommon tools you use"
    jeteater1 likes this.
  3. rivergames
    rivergames Well-Known Member
    13,973
    7,040
    Jan 7, 2008
    Nice! I've always used a vice, cut off wheel and bench grinder to round the end
    wsuwrhr likes this.
  4. lbhsbz
    3,192
    4,584
    Jan 11, 2010
    I made a 1x30” belt grinder outta a harbor freight bench grinder, Camry timing belt idler pulley, a spring from an old harbor freight bandsaw, and a few bits of scrapbinium. Gets more use than about anything else in the shop. I keep an EXL (scotchbrite) wheel on the other end. 10 seconds to clean up a cut bolt and polish the end like it never happened.
    Rajobigguy likes this.
  5. wsuwrhr
    37,047
    24,301
    Dec 20, 2007
    scrapbinium.
    Noted.
    HydroSkreamin and Backlash like this.
  6. buck35
    buck35 Well-Known Member
    3,213
    2,678
    Jan 27, 2015
    I've always just put a nut on ,made my cut ,then unscrew the nut and clean up the threads. Easy peasy.... :rolleyes:
    Blue likes this.
  7. Waterjunky
    Waterjunky Well-Known Member
    2,289
    1,060
    Sep 24, 2007
    Between a nut and the head, you can grab them quite firmly in a standard vice and make your cut without fear. A little grinder work and then unscrew the nut, just like new.
Share This Page
