Bravo Ones for Borrow
FROGMAN524
Anybody got two 34 or 36" Bravo Ones I could try out? Just want to compare to my Maximus 32 and 35s. Prop shaft is 1 7/16" so can I use my prop hub adapters or do I need different ones for Bravo Ones?
Runs2rch
Save your time. They aren't going to work.
Runs2rch
Too much slip? How about removing PVS plugs on 35 Maximus? Would that help with plane time?
PVS system only works with through hub exhaust.
The boat with the 32's rolled up on plane fine. Had to drive it though. 3800-4k and just let it roll out. With a little tab.
I'm guessing with the added power and 35's it should be similar. It isn't a light boat, so won't be a rocket out of the hole.
FROGMAN524
No issues with 32s getting in plane and have yet to test 35s. Finding best trim at WOT is what I’m shooting for before trying the bigger wheels. Right now I’ve tried both +2 and +3. Going to try neutral and +1 as well.
Runs2rch
It will always vary. Load in boat, fuel, weather/water conditions.
No one size fits all. You drive the boat for the conditions.
JD D05
I would bet our boats are pretty similar. I run 30's only now. The 32's really don't work at Powell unless I am loaded light. Havasu only.
Runs2rch
You are probably right. The non vented Heat bottom probably rolls out a little faster I bet.
FROGMAN524
What gear ratio do you have again? I’m still 1.5 after SCX conversions.
Jmp
what boat are you running these on?
FROGMAN524
Hallett 335
28Eliminator
Not True. The PVS plug holes will still ventilate enough to crate slip getting on plane whether you have through hub exhaust or not.
