Howdy, my bravo xr is leaking from somewhere underneath the IMCO drive shower. Any ideas of what this could be and how I could tackle it. I’m thinking it’s the cover assembly o-ring. Attached are a couple pictures. Thanks for the help and advice. Also the shower is cracked in the left rear corner.
I saw a small leak, and I mistakenly didn’t realize those 4 bolts take off the entire cover assembly, I thought it was just drive shower. I started to loosen the four bolts and oil poured out. Prior to loosening, they felt tight.
You won’t be able to check it/fix it without removing the shower. If the shower cap is beyond repair i have one on a shelf I’ll sell with the hose for 50$
