Echo Lodge
- Aug 27, 2009
- 3,451
- 5,441
Buddy's Rollbar Boat with 560 hours makes this noise at low RPM in forward gear. Any ideas?
What kind of boat?
I thought I saw someone with the same issue with their wakeboard boat. I believe they ended up driving it to the middle of Lake Havasu and pulled the drain plugs..
Jk I hope you can get er fixed up!
Are you referring to that slapping noise? Does it shift OK?
Thats what I was thinking as well.Check the oil mine just blew a head gasket and sounded just like that. hopefully that is not your problem as well.
This.flex plate has failed, see ron tannis' you tube video skiboatpartsonline .com. common on indmar but that should be a mercruiser
