Casale Gear ratio help
921bradyjohnson
New Member
Anyone have any advice on what size gears to run in a 12 degree casale. The boat its going in is a 1970 hondo flatbottom with a 496 BBC making around 700hp. the gears in it right now are 1.15 gears but they are eaten up with rust and I was wondering if i should switch out gears to a higher gear ratio. I am wanting to try and get a pretty high top speed and am not worried as much about how fast it gets up and goes.
warpt71
Lower River Lover
Prop size and max engine rpm will tell you where to go.
I ran 12's in my '70 Hondo with a 427 and spun it to about 7200. With the shitty old prop that got me knocking on 90's door.
We'll really need more info
921bradyjohnson
New Member
The prop is a 13 inch 3 blade, not sure what pitch because there arent any markings on it. It is also rusted and chewed up. Are 2 blade props better for speed?
bagged97taco
I would buy a 2 blade prop and keep your 15s or buy better condition 15s. Contact jj beaver for gears. If your gears and prop are rusted and chewed up. I would check your prop shaft and all running gear. Do you have a whirlaway? If you don’t, I would look into one sooner than later
warpt71
Lower River Lover
I agree with everything that Taco said. 15's may let it rev too fast, if so, step it up to 18's or 22's.
Todd Mohr
Will Race For Beer
I ran a little over 100 in a Cole TR2 at 7200 with 15's, about the same hp, got there fast as well. Had a 2 blade prop, but I don't remember the size. Sure wish I still had it.
921bradyjohnson
New Member
I plan on getting one of jj's prop shaft release kits since they run significantly cheaper than a whirlaway. Do ya'll know how much a set of gears from jj would run me?
HAP
JJ's shaft release is also a little beefier in the dogs. Great product!
921bradyjohnson
New Member
Does anyone know where I can find some reasonably priced gears (preferably used). jj won't take mine because they arent in good condition and he doesnt sell them he only exchanges them. I also need to find a two blade prop preferably used, but i havent had any luck on facebook.
Todd Mohr
Will Race For Beer
There are gearsets for sale on dragboats.com.
Bob Bitchen
Call Dave Connelly in Havasu. I know he has about 3 used sets for 12 degree.
I don't know the gear ratios though.
928-733-6013
With 700 hp, you'll want 18s or 22s. A set of 15's will cavitate the prop when even thinking about the gas pedal until about 40mph.
A good 2 blade prop is what you want.
instagator
I had the same set up as the cole, 82 TR 2,Ran 109 mph river class. Prop was 11.5 15 2-blade. I had a Stevens 1970 Flatbottom LS7 with 12 degree box and strut, When i tried to run 2 Blade prop, The boat wanted to rattle apart with no real speed gain, 12 degree strut angle do not like 2 blades...
