CATMANS X3 MAX BUILD
catman
After waiting for the 200hp frame change Can am to come out and figured that was not going to happen I ordered a 2019 x3 Max.When the car came in the first thing to do was a Evo stage 3 kit which included a Ecu flash,intake,cat delete and slip on exhaust.After doing that the clutch had to be done to get the 200 hp to the ground.When I was waiting for the car to come in I purchased 5 OMF Billet 15”x7” wheels.They are super strong and pretty light (17 lbs).
Before the car came in I was in contact with TMW Offroad in Mesa. I wanted to get all the parts that had to be fabercated powder coated done so when the car came in the parts would be ready.I had them build a cage,roof,roof rack,doors,glass windshield and ordered the seats from XXX Seats.After talking with people At TMW in Mesa I decided to go with 35” Tensor tires.Here is a pic of the same cage I had built.This was customer # 1 for there new roof rack.Mine will be powder coated Can am black.
Next was to pull the shocks and send them to Shock Therapy for there spring kit,re valve,ST bypass tube upgrade and limit straps.Also went with there sway bar and links.
After that the build list grew and the bank account went down.It is a total addiction but you want to go out and have the car handle as best it can and also replace all the weak parts that Can am uses.Next update soon...
Albert
Cant wait to see the finished product!
Hell of a way to drop 50k quickly. Should be stellar when done.
catman
Cage Is back from powder coat and getting pre wired.Car is stripped good....
Time time to bring in some good strong suspension.Brian at Long Travel builds nice suspension.Going with factory replacement boxed A arms,trailing arms and 4130 chromoly radius rods.His radius rods are built with no heim joints.You can have the strongest radius rod but the heim joints are the weak link.The is barely any toe adjustment on a Can am so the need for adjustment is minimal.
View attachment 693648 View attachment 693649 Cage Is back from powder coat and getting pre wired.Car is stripped good....
View attachment 693634 View attachment 693635 View attachment 693636 View attachment 693633 View attachment 693634 Time time to bring in some good strong suspension.Brian at Long Travel builds nice suspension.Going with factory replacement boxed A arms,trailing arms and 4130 chromoly radius rods.His radius rods are built with no heim joints.You can have the strongest radius rod but the heim joints are the weak link.The is barely any toe adjustment on a Can am so the need for adjustment is minimal.
Love those tires they remind me of the old projects with the edging.
Brian is a way cool guy and builds some awesome products for sure.
catman
The Glazzkraft carbon fiber dash is in and comes blank with no cut outs.This leaves it up to you to get creative with components.I went with a AIM dash logger.You can pretty mush have as many sensors as you want.Turbo Boost,AFR,Trans temp,Belt temp,os,fuel pressure plus everything from the ecu.I was told by a AIM rep that “the sky is the limit” with how many you can add.Added a PCI Ultimate 4 radio.Rockford stage 5 sounds and was going to go with a Lowrance HD 7 but after talking with Doug running a IPad is cheaper,bigger and the apps are endless for maps.Plus all your music is on there also.They will also run a antenna puk for the iPad.Switch Pro switch’s and that stock steering wheel is gone...
catman
Well it is pretty much buttoned up and ready to go rip.TMW did a great job and I am happy with the way the car turned out.Had to take some pics Because this car will never be this clean again.
rivrrts429
Arch Stanton...
Beautiful car. You all hit a homerun, badass [emoji106]
gqchris
Gosh dang makes my Max look like a stepchild! So bad ass, that dash and wrap are killer!
Reactions: DWC
Your car is BEAUTIFUL!!!
Colors are just awesome, looks sharp!
catman
Thanks for all the great comments.With the EVO stage 3 tune and exhaust the car hauls ass!!! My last Utv was a 900 Razor so the jump in power and the turbo is unreal..I just did the total cost and I am in the complete car for around 70K total.Not bad considering Bert’s sells there cars with a few bolts ons for that and it’s less then half of a new Buckshot.Story of my life...Buy high sell low...
Is your windshield TMW or a bent metal?
I need to get one for my x3maxx
Let me know when you want to sell it :)
DWC
$70k not bad... Noted.
The build is absolutely unbelievable. Nothing that i would change.
Compared to stock, what’s the biggest difference?
intense
The Glazzkraft carbon fiber dash is in and comes blank with no cut outs.This leaves it up to you to get creative with components.I went with a AIM dash logger.You can pretty mush have as many sensors as you want.Turbo Boost,AFR,Trans temp,Belt temp,os,fuel pressure plus everything from the ecu.I was told by a AIM rep that “the sky is the limit” with how many you can add.Added a PCI Ultimate 4 radio.Rockford stage 5 sounds and was going to go with a Lowrance HD 7 but after talking with Doug running a IPad is cheaper,bigger and the apps are endless for maps.Plus all your music is on there also.They will also run a antenna puk for the iPad.Switch Pro switch’s and that stock steering wheel is gone... View attachment 695070 View attachment 695071 View attachment 695072
What IPAD and mount did you go with?
Looks great!
If you don’t mind what led whips are those? As lame as it seems I’ve been looking for some shorties really like the idea of some 18” but hell those “horns” are sick as well.
catman
How about some better pictures of the ipad mount close up looking at that and the assault one.
Thanks
Car looks fantastic
The car is at TMW and I will be picking it up later this week so I can get a few more pics.
Here is a pic from there site.It is billet so the price tag is a little steep.They offer others for less.
catman
TMW threw those on so I will find out when I go pick up the car.
catman
TMW used the car for the offroad expo so with all the vendors at the show we came up with going with the Evo stage 6 big turbo kit and STM clutch ..Going to install a 31 gallon fuel cell under the front seats along with the stock tank for the added consumption running E85.Not Going to run pumped e85 because of having to text every time you pump and going with Torco T85.Still cheap at $2.00 per gallon.Evo supplied a small map screen that will be on the dash to go from the e85 tune to 110 race or even 91.All three tunes are downloaded in the map tuner.Running on e85 will build the most hp (260) and run the motor cool so less stress on parts...We will see ??
It’s going Haul ass and look Amazing doing it!!!
Very cool
River Lynchmob
What can I do to u for u?
Car looks great...TMW is a great shop and Doug is easy to deal with!
throttle
c ya on da lake
outstanding!
I cant wait to go back to the TMW crew with mine for another build!
catman
The stage 6 big turbo and STM clutch really woke up the car !!! It is scary fast now and ready for the dunes.Tim at OMF hooked me up with 15” wheels for the dunes.10” for the rears and 7” for the fronts.They are the lightest wheel they make for a 15” utv wheel ..13 lbs.
Icky
Hope you guys got the forged spider on your STMs my commander grenaded the aluminum one after a few seasons
Can you post up a few pics with your paddles and those OMF’s on your car
how’s your car doing any complaints or upgrades? Adjustments….
@catman
