Clanking rhino rear axle
Rondog4405
So im in the market for a rhino.. Went and looked at one today. Mid travel suspension.. Gorilla axles etc. The seller told my it has a torn cv boot on the rear outer. So i go and run it and its clanking pretty bad. He says its bcus the boot has leaked out all the grease. Does that sound right..or is it more of a bad cv joint issue? Thanks .
Waffles
What 3.slow said. Rhinos are notorious for having the rear diffs come loose and cracking at the mounting points. Worst case scenario, you need to buy a new rear diff. Best case scenario, tighten the bolts back up and buy a rear diff support for it.
Sent from my FRD-L14 using Tapatalk
Riley1
My rear diff was loose. Then started spraying grease everywhere. I bought a new (used) rear diff and the problem ended up being a loose input shaft/pinion.
Also, these are always fully locked. No limited slip in the rear. So they bind pretty bad while turning at slow speeds on the street.
Rondog4405
What's the info on the Rhino. I heard mid-travel. Depending on price, you may be able to get into a long travel one.
This one here on the threads seems pretty nice. https://www.riverdavesplace.com/forums/threads/2006-yamaha-rhino-6000.190518/
Its a 07 660. Mid travel. Gorilla axles. Stock engine with low miles and hours. Has 3 batteries.. Hid lights..winch.. Its a pretty badass rhino. Just has a torn boot. I have him down under 4k right now . i think im.gonna grab it. What do u think?
3.Slow
Its a 07 660. Mid travel. Gorilla axles. Stock engine with low miles and hours. Has 3 batteries.. Hid lights..winch.. Its a pretty badass rhino. Just has a torn boot. I have him down under 4k right now . i think im.gonna grab it. What do u think? View attachment 694023
under 4k sounds like a pretty good deal.
Riley1
Yeah. Under 4K is hard to loose on. I've changed a few boots on mine.
