Cobra 260 Razor build
throttle
c ya on da lake
CoolCruzin
few more views
3queens
Detachable Member
sweet
love the new look on the seats
kinda has the cobra head in the design ----just my observation :thumbsup
:cool
see ya in Aug on mochoppy I hope
throttle
c ya on da lake
Congrats on the new boat! The boat looks great. Your are really going to enjoy the ride and the performance. Look forward to seeing you on da lake soon.
throttle
c ya on da lake
sweet
:cool
The seats indeed are different than ours, they were not in the boat when I saw it last week- we might need to sit in one and spill a beer or two on them. The seat bases are really a nice upgrade.
How about the standard hidden Bimini... I really like having the ability to tuck it away quickly and easily when it's time for a boat ride.
I'm trying to work august out still.
3queens
Detachable Member
lol
just work the dog bite angle it should work out for ya :p
hope your ok those chiwawa bites can hurt
CoolCruzin
The hidden bimini is just bitchin . .
The seats feel good. Good back support.
cb5505
Your new boat looks amazing. Hope you take some shots on the water
throttle
c ya on da lake
Another nice upgrade that a lot of people ask about. It sure makes a difference at the launch ramp!
Sbarry
Sorry for the dumb question but why are these boarding ladders typically on the starboard side, and not the port side? I'm sure there's a reason. Curbside maybe??
CoolCruzin
Didn't even think about that when I ordered . Just looks right .
tb230razor
Saw this boat while down at Cobra yesterday....very impressive in person. Really like everything about it. Turned out great!![emoji106] Have fun!
CoolCruzin
Few more pics to check out . under the dash ,battery switch area, mirror in the cuddy .
Sbarry
Did you go with a battery isolator so you don't have to switch back and forth between batteries? Doesn't look the the typical "1, 2, and both" switch...
BHC Vic
cobra performance boats
I'm getting three batteries and a charger and I'm pretty confused how it's all going to work
CoolCruzin
yes, it has the battery isolator .No more switching .
Sbarry
That sounds like a nice new feature I am not familiar with. :hmm
Throttle.... Here's a link that goes into detail of how an ACR (automatic charging relay) works. http://www.bluesea.com/resources/1366/Automatic_Charging_Relay_[ACR]_Explained
Hope it helps. Typically found in RVs, not sure why we don't see them in performance marine application more commonly. Pretty awesome little device [emoji106]
For specific troubleshooting help with SI-Series PN 7610 and ML-Series PNs 7620, 7621, 7622, and 7623 ACRs, click on the following links: SI-Series ACR Diagnostic Flowchart or ML-Series ACR Diagnostic Flowchart.
What is an ACR, and how does it work?
What is an ACR?
An ACR parallels (combines) batteries during charging, and isolates them when charging has stopped and after battery voltage has fallen. An ACR is intended to keep a load from discharging both of the batteries.
How does an ACR work?
An ACR senses when the voltage of either of the batteries rises to a level indicating that a charge source is active (13.0V for 2 minutes). The ACR′s contacts then connect and the ACR applies the charge to both batteries. If the voltage on both of the batteries subsequently drops to 12.75V for 30 seconds, the ACR will disconnect, isolating the batteries.
Why do I need an ACR?
An ACR allows two battery banks to be connected so that they can share the output of a single charge source, allowing the user to charge more battery banks than the number of charging outputs. For example, an ACR can be used with a single-output charger, resulting in a simpler system at lower cost than a dual-output charger.
How many ACRs do I need?
To combine two battery banks, one ACR is needed; to combine three battery banks, two ACRs are required.
What are some features of ACRs?
What does ?Dual Sensing? mean?
A dual-sensing ACR will sense an active charge source on one or both batteries and not solely on a designated battery. The ACR will operate if the measured voltage on either of the terminals is of a level to initiate a connection or disconnection.
How does an ACR differ from a battery isolator?
Battery isolators use one-way electrical check valves called diodes that allow current to flow to, but not from, the battery. ACRs use a relay combined with a circuit that senses when a charging source is being applied to either battery. ACRs are more efficient than battery isolators because they create little heat and consume minimal charging energy.
Will an ACR manage the charge of my individual battery banks?
An ACR does not direct the charge to the battery that ?needs it the most? or has the lowest terminal voltage. If there is a charge present on either battery, indicated by a high enough voltage, the ACR will combine the batteries.
What Charge Sources will an ACR work with?
An ACR will work with all charge sources, including an alternator, AC charger, or solar panel. However, low current charge sources might not produce the voltage rise required to force the ACR to combine.
What else do I need to know about my ACR?
What are the minimum number of connections I need to make my ACR work?
Three: One wire to each battery, and one for a ground (GND) connection. For safety reasons, remember to disconnect the negative battery connections before beginning any ACR installation. See this article for more information on selecting the right fuses for Blue Sea Systems ACRs: See Selecting the Appropriate Fuse Rating When Installing the 120A SI ACR
What does ?Undervoltage Lockout? mean?
As a safety feature, some ACRs prevent combining into a severely discharged battery. A dual-sensing ACR will monitor the voltage on both batteries and will not connect if either battery is below the undervoltage lockout level. Use caution when combining into a battery with extremely low voltage, because this might represent a faulty battery or a problem elsewhere in the system.
Why doesn't my ACR automatically combine every time my engine is running?
For an ACR to automatically combine the batteries, voltage and time thresholds must be reached. Although these numbers vary somewhat from one ACR product to another, if ACR terminal voltage is greater than 13.0V for 2 minutes, the ACR should combine.
Why didn't the ACR disconnect when my engine was turned off?
The ACR will not disconnect until the low voltage threshold is reached to isolate the circuit. It may take several minutes for the voltage of the batteries to drop to this level. Since the ACR incorporates a delay, additional time (up to 2 minutes) is required before the ACR disconnects.
Where can I get more troubleshooting information?
CoolCruzin
Couple pics from getting the boat wet in Havasu.
Got to say Cobra did it again -Zero issues with the new boat .(thank you Cobra guys !)
Handle the water very well .Water was ruff with the storms the 260 Razor plowed right on thru it.
Performance was great running the 8.2 HO. I'd say it was a great step up in boat size .
Wife was happy!!!!!!(best part) She didn't think she will like the cuddy being crawl thru vs the walk thru we had but she did.
She was down there just to get out of the sun a few times .
Can't wait for the next trip out .
