DiMarco21
- Dec 20, 2007
- 138
- 12
New Super V-Drive Billet 10 Degree V-Drive Cases
Made from beautifully machined 6061-T6 aluminum for Schiada Boats. Uses a 5/16" bolt through design for superior strength with small counter-bores on front face to conceal possible bolt galling.
Raised water jacket to allow a 80% gear ratio with a 38% minimum gear ratio. Also featuring a lower water jacket for COMPLETE v-drive case cooling.
The Super V-Drive is approximately 1/2" taller and 1" wider (left to right) than the standard Collins billet cases. Thickness stays the same (front to back).
Uses off the shelf standard quality Casale parts. 1/2" thick mid-plate design to prevent v-drive flex. Machined spot faces on front of case for possible v-drive water inlet and outlet ports. Standard water ports in rear of case are machined in for you. Extra thick 1/2" case flanges, this v-drive is built to last!!!
You will have to use our Super V-Drive 1/2" mid-plate and gaskets.
This part is the result of a collaboration between Daryl Collins and Stan Murakami of Schiada Boats.
Sold exclusively at D21 Enterprises.
Thank you, Phil
925-323-9093
Thank you, Phil
925-323-9093
