Found them here from 03-04 https://www.riverdavesplace.com/forums/threads/low-water-pix.133909/wow, when are those from?
The water flows drops pretty good towards the end of october, then they usually bring it back early February. I'
I see what you did thereEspecially in Parker. It's best to stay away from That place!
Some pretty good data here. Not a lot as far as river flow historically, although there is daily data from the recent past. Lake levels back to 1935 if you dig: https://www.usbr.gov/lc/riverops.html
I actually check here before I launch just to see what the level and plan is.
I'd love some hi res pix if anyone has them. I want to do the Lake place up with historical pix.
Wheeler said his pics were lost in a fire in 1980! He suggested Skyskier as well. Thanks
I wish I would of took a few from last weekend, water was as low as I have ever seen it besides the first of the year when they drop it for 2 weeks. I think you could of walked across no problem at big river by the bridge. I'm offshore pretty good and I was sitting on bottom a few times and ski was high and dry.
How deep is big river at high level?Water was low last weekend on the lower river as they did not want to release water down south due to Hurricane Rosa expecting to make landfall over flood concerns.
Here is Big River last weekend:
With the amount of rain forecast, orders for irrigation water was way down. Plus the lower temps reduced need for hydroelectric power. The fact that room was needed for possible flood water influx completes the trifecta.
It's easier and safer to make room beforehand, than deal with flood levels after the fact. Remember that recreation is the lowest priority for Colorado River water. Water delivery, storage, flood control and electric power generation are at the top. Recreation is somewhere a few points down below catfish habitat.
When I was a kid and we had a place in Bullhead in the Wagon Wheel trailer park this is what the river looked like every single Sunday morning for all of the 1960's. You could almost walk across the to the Nevada side, there was no Laughlin...it was paradise, except for the very center channel which we had to swim. These pics c_land posted above were taken very close to where Wagonwheel was/is. I really need to get our home movies transferred to a digital format and post them here.
View attachment 689328 View attachment 689329
That almost looks impassible when low.
Sent from my SM-G930P using Tapatalk
1983
Dan'l
That was kind of a different situation. The '83 floods were caused by Bureau of Rec (BOR) showing off.
Glen Canyon Dam was finished in 1963, which created Lake Powell. It was estimated (accurately) that it would take 20 years to fill to full pool. In early 1983 BOR wanted to show what a great job they did and filled all the storage Lakes (Powell, Mead, Mohave, Havasu) to 100%. They didn't anticipate a late spring heavy snowfall in he Rockies, followed by an immediate warm spell melting all that new (and prior existing) snow. More water flowed into the system than they had room for. Davis Dam was nearly breached. The Parker Strip flooded homes and campsites and was closed to all boating, as was Bullhead and Needles.
To date, no one got nut swung over that fiasco.
I remember this deal as well...
You have any Good pics of the gates partially open? Man that was a sight to see.
I've got this one in my office.I remember this deal as well...
Wow i Didn't know that. It sounds like the same thing that happened at oroville last winter. https://www.popsci.com/scitech/article/2003-03/water-vapor-almost-busts-damI didn't know about Davis. I know Glen Canyon Dam was literally cavitating into the bedrock and some knowledgeable people have said they almost lost the whole thing. They literally extended height with plywood
Most likely relocated and given a promotion ...That was kind of a different situation. The '83 floods were caused by Bureau of Rec (BOR) showing off.
Wow ! Cool pictureI bought this pic from the Chicago Tribune take 9/1939. Building of Parker Dam. Can not get any lower water level.
It's only like 20 feet at the buoy line below parker dam . There are some really deep pockets on the parker strip though .Wonder if any channel excavation done prior to filling Lake Havasu. By Fathometer most of the River channel depth is about 50’. Deepest spot I’ve seen is at the point below Five Fingers on the CA side, about 80’. Never checked the depth at Parker Dam prior to 9/11 and the restriction buoy line. Would think that would be fairly deep.
