Try the new Mercury Bravo OC's. They are made for twin OB cats only. I have tried them and love them.
That prop looks like a vented Bravo 1 Not sure how it's that much different than a B1 with "PVS" vents.
14.75" vs 15.25" diameter
Re-shaped blades to match the smaller diameter
8 hole PVS vs 4 hole for better tuning
Further shortened exhaust barrel
Got it:thumbup: I loved my vented B-1s and the BBlades I tried were Iman's. Those were awesome props too. It sounds like Merc has finally dialed in the right props for cats with OBs. I suspect the resurgence in OB popularity with the introduction of the 300XS has helped fuel the fire.
I have a few sets of props if you are interested
Havasu
It is a Bravo 1 with 2 holes and the exhaust ring cut off.
I have been running Bravo 1's with this done to them for 3 or 4 years, they work great on my 25 Eliminator Daytona with twin 300 X motors.
Good hole shot, top end around 96 mph. can pull skiers and haul a boat load of people.
Pretty sure its not factory drilled vent holes if it has 2 or 4..the aftermarket prop shops started doing these mods way befor mother merc jumped on bandwagon..Just 2 holes? Mine always had 4, one for each blade. I think my holes were 1", what size are the new ones if they are just running 2?
These holes only affect holeshot,all modern outboard bravo props have 8 total (two per blade)that give it more tunability..Merc has PVS plastic inserts to plug completly or make the 1" hole smaller
Are these Motors on Mach22 3.0 300HP or 2.5 drag 300HP??big diff when selecting props..
cant imagine twin 3 liters on mach22,but crazier things have happened..
What pitch did you order?
I run 28's on my 25 Daytona.
