Direct Tv help in Havasu
kevnmcd
I just recently switched to direct tv at home and got an extra box for the Havasu house. I have a dish already up and all the cabling installed but need help connecting it to the house cable outside in the cabinet by the electric panel. Anyone have a contact out here that I could call that could help? Thanks.
WhatExit?
Your sat cable needs to run to the DTV box - no need to go into the cabinet - go from the sat into the attic or through the wall and run it to the DTV box
satellitemike
Not sure about your set up but if at your cabinet you have a multiswitch. If you connect the receiver in the house to the cable it will put 12/18 volts into the cable line and if you have a volt meter or your tongue you can find the other end in the cabinet. Only thing you need to make sure of is there are no splitters between sat box and your cabinet. if you identify it, all you need to do is plug into multiswitch.
satellitemike
That's another way to go if his place isn't set up like my previous post. Lot more work tho!
kevnmcd
This isn’t my forte. I just need someone to come do it for me. I will pay. [emoji1360]
This is who I used for DTV work......
tostark
Liquid Equity
Havasu Audio Video did mine. 928-855-3111. They are on the southside.
kevnmcd
Called Nate and he came over and took care of it. Good thing too. Had to run a new cable from outside to the garage to connect to the cable in the house. Thanks for the contact.
