Distributor clearance
enemy
So I just dropped a new motor in my boat and the distributor cap is hitting the engine hatch [emoji853] does anyone know if their is a shorter distributor cap available for the msd billet distributor. I see they sell crab style caps on the website but I think they only work on one specific distributor that I don’t. Have. That would be an easy solution if it worked or if their is an aftermarket one that works. Msd won’t answer the tech line no matter how long I wait on hold. If anyone has any creative solutions I would love to hear it. I would prefer not to have to cut the hatch to make clearance or to trash a brand new distributor if possible.
renodaytona
I think you’ll have to get a whole new distributor. The crab style is only for crank triggered systems but there is this one:
enemy
Dam ok thanks
Real talk, I’d call Summit, they really seem to know their shit.
obnoxious001
Engine building character
What sort of distributor did you have before that cleared?
MSD does have two different style caps that work on their standard distributors, but not sure one is much shorter than the other. One uses female HEI style ends, and the other uses older school male ends. If you haven't already corrected your problem I can compare the two of them side by side, I am sure I have both styles in the garage.
enemy
It was the stock mercruiser motor and distributor. It’s definitely shorter then the msd. I’ll have to look for one of those caps. The one I have now is the hei style and I bet the standard one would be a little shorter.
enemy
Yes if you don’t mind checking to see the difference I would appreciate it
obnoxious001
I should have a Mercruiser distributor being dropped off tomorrow fpr an engine I just completed that I can compare against an MSD I didn't see that you had replied to my post until just now, I do have both styles of MSD caps here, will see what the difference is in height.
obnoxious001
Mercruiser distributor did not get dropped off yesterday, but you should be able to compare yours. The older style MSD cap may be 1/2" shorter with the wires in place, not much. If you haven't already it would make sense to call MSD to see what they can offer you.
enemy
Thanks a 1/2 inch may help I’ll have to call them again. I tried a few days last week but just sat on hold for a good half hour
obnoxious001
Got the Mercruiser distributor,, roughly 1" shorter than the MSD I think. If you don't want to modify the hatch you may be stuck with the Merc. There are some parts available still, but not cheap I think, friend has new module and distributor on the way for the engine I just put together for him.
enemy
Thanks for all of the help. I’m going to take some measurements and try to figure out how much room I would need.
