DIY Surge Brake Lock Out Key
LazyLavey
Another quiet rainy day in the garage
"Boyz on a Budget" fabs up a Magnetic Lock Out key
HF telescopic magnetic pick-up tool end, Bout $4
1/16 SS cable, ferrules and rings, Bout $1
Misc Blue Screw Condom
Savings.... enough for a Coors Light
Albert
Is that key used reversing up a hill? Never used before
A nickel works when needed and dam key gets lost.
Anytime you're backing up so the surge brake doesn't engage
If you are always using the same truck connect the blue wire to your back up light. Should be a 5 wire connect for trailer.
