What happens now is that if I have the nozzle all the way up to throw a rooster tail, it porpoises like crazy.
I have a 20.5 open bow commander with a 454 and Berkely JG pump, ride plate and place diverter. I imagine my front seating gives me more bow weight than you, but with 40 gallons of fuel, in saddle tanks, 5 adults, empty bow, ice chest and gear, I can get on plane easily with full down trim. At speed, I trim it up just enough for the steering to free up a little and you can feel the boat kinda slide forward as the bow lifts and things line up right which lets me drop the RPM a little and cruise. With this load, if I trim it up past the sweet spot it immediately starts to porpoise and gets progressively worse without correction. I need 3 full sized kids or a couple of adults in the bow to trim all the way up and keep the porpoising under control. Also, I can stuff 8 adults in there with full gear, and while it's a pig, it planes easily full down trim and cruises nicelyI have a 1994 Advantage 20.6 foot jet boat with a 454 and American Turbine pump with Place Diverter. Only had it for a month and it porpoises really bad. I've had 3 different flat bottoms over the years and have never experienced this with a boat. It doesn't have trim tabs or anything. So what I'm wondering is will a droop snoot solve my problem? I was thinking some trim tabs or something. The boat struggles to plane out. Getting her out of the hole is hard on the motor and pushing more water then anything. I'm constantly trimming it all the way down but then it doesn't wanna make any progress so I trim it up and it just porpoises bad. Theres so much weight at the stern between the big block motor, 2 batteries, two 22 gallon saddle tanks more towards the rear of boat plus all passengers. The bow is empty, hollow, no weight so I put 2 sand bags at the front under the bow and it really didn't do anything but add more weight to the boat. What does this boat need for better performance? Ride plate? Droop snoot? Trim tabs? Maybe all of the above? Some info would be greatly appreciated
