beerrun
- May 25, 2010
- 4,241
- 7,562
Is the straight line on or the circle thanks
Line is on o is off
It's about making it universal around the globe and not having to print switches in a hundred different languages.On and off was too expensive to put on the switch
I’ve heard it explained as binary numbers. 1 is more than zero, therefore 1 is on, zero is off.
Exactly, so they make it in a language that no one understands. There's probably a thread going right now on Zimbabwe Dave's asking the same question
Fixed it for yaYup, bits that are on or off.
Learned it in Cisco networking classes and subnetting IPv4 addresses. Not fun. At least, not for this old man.
Streaming/digital music nerds also get worked up about bits.
I’ve got 99 problems but binary isn’t one of them! <--------- figure that one out
Did you unplug it for 30 seconds and then plug it back in?Thanks everyone doesn't matter what position its in heater still not working. Taking it back to the manufacturer on Monday
Unplug what i purged the propane again and tried that switch in both positions and did it while running the generatorDid you unplug it for 30 seconds and then plug it back in?
So your tankless water heater and your trailer heater isn't working?Unplug what i purged the propane again and tried that switch in both positions and did it while running the generator
Sorry no the water heater works the heater does not. The inverter does not and there are switches that don't work for lights so at this point we are camping this weekend with family in chula vista then I'm taking it back to the manufacturer on MondaySo your tankless water heater and your trailer heater isn't working?
Ok, because the pic you show is the water heater....Sorry no the water heater works the heater does not. The inverter does not and there are switches that don't work for lights so at this point we are camping this weekend with family in chula vista then I'm taking it back to the manufacturer on Monday
Guessing people didn't know that you had a tankless, my new Vortex doesn't, but have a switch on the outside to use electric for the water heater.Yes because people keep say there is a switch on the outside and that was the only one I could find
Does the ac turn on when you change the mode to cool/ac?
So 1 thermostat for both AC's and they work individually as well?Yes both A/Cs work
Winner winnerFixed it for ya
