Electrician Question
Sleek-Jet
You mind if I share your story with my people? Great illustration of how customer service attitude can make all the difference.
Christopher Lucero
Yeah, that 30 amp solution would run his shop with plenty left over. Is there an option to make the sun shine at night?
:rolleyes:
well, he did say 100 amps was not really a requirement...
I do not think I will need 100 amps
but it is always good to build in some margin to the system
nonetheless
knowing you are an electrician I will not second guess your mockery of my proposition. I humbly submit that even after adding a battery bank an off grid solar solution is competitive. but, being that you are an electrician, I defer to your expertise to help the OP through this build. best regards.
rrrr
nonetheless
What good are batteries? They have a finite run time.
CarolynandBob
I am surprised you did not consider a solar solution. full 4kW 120VAC kit is around $6k on ebay. you can upgrade to a two phase or three phase inverter for around $2k more.
I need constant power for the camera's when we are gone. We spend winters in Florida and want to have cameras running. Plus I need about 55 amps when I turn on the a/c. Another reason is I do not know what the future holds. May end up running a welder in the future.
I did really research a generator. Even to get a big enough one to run the a/c. Also researched solar powered cameras. In the end I figured it just wasn't a good long term solution.
Christopher Lucero
wow. I really respect your authority, but I am perplexed that you are unaware of how off grid solar works.
excess charge provided by solar generated electrons is plated onto batteries during daytime for consumption during cloudy or nighttime consumption.
my own home has a single phase system that can run indefinitely should mains power fail or be turned off. but it is single phase so my A/C unit and oven are unpowered when the other phase is removed. nonetheless, the system charges during the day and we use excess at night (if mains are out). we are in a high insolation area at south 34 degrees.
I am going to go fill in the blanks for you and the OP by roughing out a possible system that may work for him (and you I suppose).
got it. if you are not already dead set against considering a solar solution, can you provide just a few details
...where is the home? how many inductive loads? I know about the A/C and will assume 55A continuous...anything else with +++ inductive or high inrush? expected average continuous load when you are in there working?
No worries. continuous power is possible. the off grid thing is popular in Germany, so even northern climes can be engineered.
Your cameras will be subject to interruption of internet service I suppose, but we can even engineer a small generator backup as double redundancy in case the batteries deplete under snowy or cloudy conditions. maybe even triple redundant with a small circuit from mains to run the cameras alone in case of gen/solar incapacity, rather than a buried 100/200/400A line.
hmmm...was that an edit? a welder. will investigate.
CarolynandBob
Welder maybe in the future. Nothing else with high load currently. Expected load when working I was thinking 60amp. The a/c I am looking at is 30amp. Shop in in west Tennesee. Town of Big Sandy. Isn’t solar a much more expensive option initially? I had solar on my home in San Diego. Yes the electric bills were nice, but no battery etc. That was a $52k system in 2003. $26k after rebates.
As I said we are only there 6 months, so I do not think the cost vs benefit would work out. You can give me the ball park number on a system you are talking about. I am always interested in different ways and learning something new.
Christopher Lucero
sorry, I did not catch this post earlier
this project
...you are already going in with easement and trench and have bought conduit. so sorry if I have bothered you.
but I still will exercise myself as a personal curiosity and to help make the c/b tradeoff clearer.
What are the rates at Big Sandy Co-op?...might help me when doing the payback period.
rrrr
I know how solar systems work. :rolleyes:
You claim your home system will stay up "indefinitely." But in the next paragraph, the undeniable fact emerges. As I said, batteries have a finite capacity. Your answer would be to provide more batteries.
A solar system would be an expensive and unsatisfactory solution for the OP's requirements. Your suggestion to provide a generator to power his cameras, a one or two amp load, is laughable. No competent engineer would consider such a thing, unless, of course, he was trying to sell a solar installation.
But go ahead and peddle your psuedo expertise.
CarolynandBob
You have not bothered me at all.
Yes I have the easement and bought the conduit. which can be returned. Won't start trenching until the first week of June.
Co-op? I assume you are talking electric co rates. In April we used 49kwh and was charged $28.20. We got back here in April 23, so a lot of that is a base rate. We leave the heat on 55 deg when we are gone. Only other thing on is the cameras and router. Back in May of 2020 we used 474 kwh and was charged $76.89. We were here the whole month of May. I am assuming you divide 76.89 by 474, which is 0.16221519 per kwh.
Christopher Lucero
OK. I will. Thanks for being a source of problems to solve.
I obviously do not agree that solar would be 'expensive and unsatisfactory' before the fact of examining an engineered solution, and cost analysis. I do this because it has been demonstrated dozens of times for me and friends to be cost effective, so our experiences are divergent.
You are likely expressing an opinion from your experience.
I have been told RDP is a friendly place, but disagreement you are expressing your opinion and the tone of it is somewhat unfriendly and hostile .
I am not an installer, just a DIY guy that has found that the DIY route and owner-builder option is nearly plug and play, and personally fulfilling, and economically attractive.
I am not selling anything, not going to make a dime for my effort...I'm just hoping to help a fellow American, a stranger, because I can.
SO on the odd chance that I somehow got in your knickers for being so bold as to examine as solution for free for the OP, who himself is somewhat more friendly and tolerant of my initiative, and more aligned with what I am told is the RDP culture...
...on that odd chance that you are upset, here is a clip from Seinfeld that may help you by providing a chuckle.
Best regards.
UPDATE: rrrr did end up being right about the solar solution being unsatifactory. The solar project could not economically accommodate high and very temporary peak demands and long periods of dormancy over the winter while c&b were away.
CarolynandBob
If you look close you will see that is a different machine in the second pic. Hit rock and needed a bigger excavator. Even that one didn't get through all of the rock. Will get the jackhammer attachment tomorrow. Will get more pics today, but we are about 2/3 done. A lot can't get done until tomorrow, because it goes through driveway and road that I want to close up quickly. Will need the inspector to give the ok in order to close.
