Fender rock guard
Blownbillybob
What are people using on the inner side of the fender as a rock guard
My old 1s are wood in good shape but wanted to upgrade to a better material then wood ?
I haven’t, but thought to do a set out of 1/2” birch, glass the carriage bolts in than have them shot in LineX. My boat sits a ways over them so no worry of damage to boat and should look good and last a long time.
240Hallett
I used this 5/8 thick nylon (I think) material. Cuts and drills pretty clean. I don’t think it would scratch or leave a mark on gelcoat.It’s not “blingy” but you would probably never need to replace it. This is a rem from the corner cut on a bandsaw.
Where did you get this material?
Cole Canadian
Matches the black fenders…
don’t mind the fender alignment… I was still adjusting.
Used the same product on my fenders 3yrs ago. sanded with 80 grit and glued marine carpet to hull side, stapled over edge with stainless steel staples on wheel side. No issues und will never have to replace.
Do you know what exactly that material was/is?
n2otoofast4u
LazyLavey
I'm considering an ABS type material with the ability to glue and staple carpet. Only wrap and staple the top and sides.....Do not wrap the bottom,,,
staple only... to eliminate water from settling in the bottom and premature carpet rot
Cole Canadian
It was called Puckboard. It's used on various construction projects and of course around hockey rinks;), comes in a variety of colors and thickness.
Should be able to get it from your local hardware outlet or have it ordered in. It's made from polyethylene.
I used the 1/2in for mine.
BUDMAN
HAVASU BOUND
Good to know. Thanks for the info. The stuff I’m getting is used as a scuff liner in the semi trailers to keep the fork lift drivers putting pallets through the side walls
Got the composite material from @BUDMAN, works awesome. Easy to cut, used a table saw for to cut the height, the a jigsaw for the radius, than my router for making the cut edges match the edge that it comes with.
Drills easy as well, was nice & easy to use my countersink for the stainless bolts
All in all should be an awesome upgrade as it should last 10 years or more with absolutely no problem.Tomorrow for the other side, should be a bit easier and faster on round two.
Thanks again @BUDMAN
BUDMAN
HAVASU BOUND
Got the composite material from @BUDMAN, works awesome. Easy to cut, used a table saw for to cut the height, the a jigsaw for the radius, than my router for making the cut edges match the edge that it comes with. View attachment 985435 View attachment 985436 View attachment 985437 View attachment 985438
Drills easy as well, was nice & easy to use my countersink for the stainless bolts View attachment 985439 View attachment 985440 View attachment 985441 View attachment 985442 View attachment 985443 View attachment 985444
turned out great. I definitely have to upgrade my trailer. BTW your welcome.
OC Mike
Looks great!!
Any plans on carpeting it?
$hot
To say what? :)
probably going to do this too!
Looks great!!
It’s a plastic material designed as a rub rail in a semi trailer, as well for my boat it sits up above it. I see no reason whatsoever why carpet would beneficial at all.
240Hallett
Agreed. Carpet would serve no purpose with this stuff other than collecting water.
