79 HUSTLER
- Dec 20, 2007
- 2,561
- 2,931
I have a 2008 F450 4x4 with the 6.4 and low miles. I am having a vibration in the seat that starts once I hit 40-45 mph and I cannot diagnose. Below is what I have done so far:
-new rear driveshaft built and balanced up to 3,500 rpms (even removed and took back in to double check) .
-all new u-joints as well as new carrier bearing.
-rebalanced all tires (only 800ish miles since new) and one was a little off but still no help.
-ran a dial indicator on all four rear rims with zero movement.
-ran a dial indicator on the rear transfercase flange with zero movement.
-ran a dial indicator on the rear diff. flange with zero movement.
-placed the rear of truck on blocks with all four rear tires on and ran it up to 45-50 and vibration was still there.
-removed all four rear tires while blocked up and was able to run up to 80mph with zero vibration (points to the tires being the problem I would assume ).
-took the truck into another shop to balance tires (again) and they did not need to add a single weight as the tires are balanced.
What am I missing before I tear into this rear end ???
**UPDATE** I wanted to see if I could rule out the rims/tires so I used a pair that are definitely good and just ran one on each side. Hit the highway and the vibration started at 45 just as it had before. Might just end up being a long weekend effen with the rear end.
