500bbc
- Oct 16, 2007
- 26,497
- 40,399
I knew that was coming. It was a few years ago. I will have to poke around the net. Like Chris, I was look to the net for help and came across a website.
Removing Odors from a Hot Water Heater
Replace the magnesium anode. The magnesium anode is connected to a plug that is located on top of the water heater. Consult a water heater dealer about a replacement anode for your make and model of hot water heater.
Disinfect the water heater:
Turn off your water heater and close the cold water inlet valve.
Turn on a hot water faucet and the temperature and pressure valve. Allow 1 gallon for each 30 gallons of water heater capacity to drain out.
Add 1 gallon of household bleach per each 30 gallons of your tank's capacity. Fill the tank will water by opening the cold water inlet.
Allow the bleach to sit in the water heater for 1 hour. After the allotted time, open the cold water valve and all the hot water faucets to allow the bleach-water mixture to clean the pipes.
Drain the remaining contents of the water heater through its drain valve.
Close the drain valve and fill the tank with water. Allow the water to sit for 15 minutes and then purge the hot water supply lines and drain the tank. Be sure to purge all the air from the lines.
After the system has been cleaned and purged, turn on the water heater.
Increase the temperature on your water heater to 160 degrees. Allow the heater to stay at the increase temperature for a few hours to kill the sulfur bacteria. After a few hours have passed, flush the system to remove the dead bacteria.
Read more at Suite101: Get Rid of Sulfur Smell in Water: Removing the Rotten Egg Smell from your Hot Water Heater http://homemanagement.suite101.com/article.cfm/get-rid-of-sulfur-smell-in-water#ixzz0qs9mF9ca
Third step you should replace the aluminum anode rod with a magnesium anode rod cost is $20.00 to $30.00, which will not produce that terrible odder that aluminum one does. Some people remove the aluminum anode rod without replacing it. This is a bad idea and will accelerate the corrosion to your tank.
Read more: How to Eliminate the rotten egg smell from your water | eHow.com http://www.ehow.com/how_4819522_eliminate-rotten-egg-smell-water.html#ixzz0qsA9JI72
Cpoy, print, keep at river house.
