j-bone
- Apr 22, 2015
- 565
- 494
So I've got a 2005 Carrera 257 Party Effect. It has dual 35 gallon tanks. It has a fuel switch and one fuel gauge. When the I switch from one tank to the other, the fuel gauge adjusts to the tank being used. Unfortunately, the gauge is wrong on both tanks. I have run out of gas in one tank when it registers 3/4. I would really like to have an accurate gauge. When I had the problem checked out, I was told the sending units were fine, and that it was the fuel valve that was the problem.
So, my question is can I just add another fuel gauge so I could the level of gas in each tank at all times. I was thinking if the sending units are fine, the gauges could be wired directly to the tanks. Or is the only option to replace the valve.
