Fuel pump capacity
enemy
Just replaced my stock motor and I’m wondering if the stock belt driven mechanical fuel pump will be sufficient for the new motor or if I need to replace it. It’s from a 98 454 merc 300 hp and I put in a 500ish hp carb motor. If I should replace it will just any after market mechanical pump work or does it need to be something special with the belt drive. Looks like the same thing to me but haven’t pulled it off to see.
Riverbottom
Any marine Big Block Chevrolet pump will work. I would look carefully at the inside diameter of all those bass fittings. Some of them can be petty restrictive.
enemy
Thanks. So are you saying I should replace the fuel pump then? I am replacing all the fuel lines and fittings with braided and AN fittings just temped it up to start it.
Riverbottom
If it is really 22 years old, I would replace it. Just my opinion.
enemy
Haha ya good point. I already have a new one lol
28Eliminator
Not ANY pump will work. the Water pump driven Gen V/VI pump has a proprietary arm designed only to work for the Water pump/fuel pump provision.
enemy
Oh shit. Thanks for pointing that out. Is what I have one of those or can you tell me how to check?
Kylemenz1
Yes you have one.
Is your new motor a GEN VI block? If so get a new fuel pump that fits your current setup.
If it is not a GEN VI block it should have a provision for the mechanical fuel pump on the block. Then you would not need your current setup.
The fuel pump setup you have is because the block you’ve got was meant for vehicles with electric fuel pumps. No big deal, just get the correct fuel pump for it and you’ll be fine.
!!!DON’T FORGET TO ADD OIL TO THE FUEL PUMP HOUSING IF YOU KEEP IT!!!
Ask me how I know how important that little detail is!?! If you forget to add oil the whole unit will seize. You’ll be stuck on the water and out $1000.00 to replace it.
28Eliminator
Yes, thats what you have. Merc only makes 1 fuel pump for that set up, and its the same one used for the HP500 as well, so it will be plenty for your future set up.
enemy
The new motor is actually a mark IV block so it will accept a mechanical pump but the pump housing is in the way so I’m stuck using the belt driven one or going to an electric. Thanks for the heads up about the oil. Don’t want to learn that lesson the hard way.
