We're installing a naturally aspirated 700hp 540 in our Howard Cat. I'm getting ready to plumb the fuel system and have some questions.
The motor is running a 1050 Dominator with a -6 line supplying each float bowl. The two -6 hoses goes back to a diverter fed by a single -8 from the mechanical fuel pump.
On the other end of the fuel system we have two tanks with 3/8 nipples for the fuel line. Each fuel tank goes to a tank selector that has provisions for 1/2" fittings. The fuel then goes to a fuel filter/water separator that has 3/8" fittings. From the fuel filter it goes to the fuel pump which has -8 fittings.
I was thinking about upgrading the fuel filter mount to something that supports -8 fuel line so I can run -8 from the tank selector to the fuel pump. However, logic is telling me it doesn't matter as the tank pick ups are 3/8". What do you guys think? Here some pics for reference.
