Fuel Valves/Switches
bajagrom
What fuel valves, fuel switches, fuel blocks, are you using. I have seen most of them on the net but which ones good, bad, and ok. I have 2 30 gallon gas tanks in my Campbell that are feeding a BBC.
Soldout
Park Supervisor
The deluxe would be the superfuel valve. After that there are a bunch of options and ways to do it.
Boat Anchor
Peterson Fluid Systens has some very trick ball valves that could be used for fuel shut off valves (selector valves). You would have to run one valve for each fuel tank to a "tee" and then to the engine. This way you could run with both valves open or one valve open at a time. Just another choice.
http://www.petersonfluidsys.com/plumb_ballvalve.html
