Rayson1971
- Nov 23, 2017
- 1,275
- 2,107
I have a 19' mini day cruiser I'm gonna regelcoat. Should I buy the gelcoat with or without the wax. What's the difference and why?
Pretty close!I no expert by any means but I've repairs miscellaneous chips and beach rash on my boat.
Gel without wax will not cure in a timely manner just being exposed to air. This allows you to make multiple coats. The last coat will need be covered in cellophane and another spray product to fully cure so you can start the sanding and polishing process.
Gel with wax cures without a further need for a sprayable top coat or cellophane. The wax magically floats to the top allowing the gel to cure. If multiple coats are needed, you'll need to remove the wax after the first coat has cured.
Now I could be full of shit..., but that's the basics.
Out of the can gelcoat without wax is air inhibited, meaning it will not cure hard. Is designed this way for secondary bond, Be that more gelcoat or lamination.I have a 19' mini day cruiser I'm gonna regelcoat. Should I buy the gelcoat with or without the wax. What's the difference and why?
Correct. As long as the wax goes on after the Last coat.Seems like it would be an easier process to spray on the wax coating after than buying gel with wax. Then I could also spray more coats . Correct?
Those were the days!We need more lemon pledge
Sent from my SM-G900T using Tapatalk
I don’t recommend it. It leaves a bit of an oily thing that actually draws dust.Serious on the pledge? What spray on wax will work or is recommended?
