I have a 210 hallett... 454 mag, belly tank.. I think the big block is a lot of weight on the rear of the boat.. I'm changing the manifolds to aluminum..should save 60--80 lbs(quessing) both the batterys are all the way to the rear starboard side.. the question is, would moving the...
The Hallett legend began with custom ski boats over 50 years ago. That legend lives on with the 210-S, an exciting family sportboat that delivers impressive performance with V-8 Mercury stern drive packages.
The average fishing boat trailer weight will probably be around 600 lbs. There can be a fairly large potential range for these trailers however, running from just a couple of hundred pounds at the low end to well over 1,000 pounds at the higher end of the scale. And that’s…
