Gelcoater
- Sep 26, 2009
- 21,680
- 36,561
Very nice. To my knowledge It's been a long time since a brand new 210 was built. :thumbsup
I wish you did my Boat your work is always perfect.
Can't be that long.
Can't be that long.
I want to say it has been a couple of years since they did a new 210. I could be wrong though I would have to ask Jerry.
Going there Monday to talk on a 290.
Nice that will be a nice boat. I have to talk to Jerry to and ask him how big the gas tank is in a 93 210 closed bow.
It is 80 gallons. Has been since it was built. I just ordered a new tank for our 89 27. Same now as it was then.
Running surface and pinstripes are platinum grey.
Silver sides,a charcoal faded stripe with HOK silver Pearl separating the silver and,wait for it.....
Deep lime green to lime green cap fade,with HOK Ice Pearl.
A medium gray with HOK silver Pearl goes over the charcoal and into the green.
View attachment 493580 View attachment 493581 View attachment 493582 View attachment 493584 View attachment 493585
If im not mistaken... same graphics design as the one you did for us?
Below the rub rail yes,pretty close.A couple of minor differences.The deck design is very different.
You spray at the old shop right? Or will you be around today?
I should be getting some pics from Jerry in the next day or so of where they're at on the build.
This unit is headed to Washington state,getting the 350hp 6.2 Mag HO.
Looks like they're close to bonding the deck and hull together.
View attachment 496106 View attachment 496107 View attachment 496108 View attachment 496109 View attachment 496110
What's the word?
I don't build boats.. but is there a benefit to more than 2 stringers in a 21 foot boat?
My old 21 had an issue, I was told it should have more stringers than the 2 it had.
In some cases yes.
Was your 21 fully balsa cored?
Hallett builds them like a brick shithouse.
A typical 21 in my opinion doesn't need a full balsa core like this.Many builders bypass full balsa and use core mat.Its cheaper but not as strong,so the second set might be needed.
But,this isn't a typical 21,it's a Hallett 210:cool
Is this a standard build? Are all 210's past and present balsa core?
In some cases yes.
I am digging this, I like that it is "still a hallett" in terms of gel designs and shapes, but pushing the envelope and a bit more wow factor. :thumbsup
:thumbsup
It should have some bling in the sun.The gray base,dash,etc is silver metallic,both gray stripes have some Pearl powder and the green has ICE Pearl from HOK.
Thanks for posting all these, I truly appreciate it. If I could make a request, one time you are doing these pearls and flakes and all that, could you snap some photos showing the process? Never seen it all come together. Do you do test samples that you spray out to make sure it all pops the way you want?
