Happy Hour, Happy Hour going in for a complete makeover
Nailhead
Rainy Sunday window progress. Before and now
wettrthebettr
Holly Molly, Your new home will look better on land now.
Excellent Job, You will be the new Strict Captain on the water. LOL
I would, be checking for mud, sand, shorts with Bling on them, all and more
Not aloud aboard.
Blownbillybob
Who did ur strut and what did u change it to??
Any thing on ur hyd steering?? I’m going for it on my boat getting pieces together now??? Will see !!!
Nailhead
Lance Stump built the strut, 9* moved to 24" forward of the Transom. Still have room for a 13" prop. Going with a seastar single ram hydraulic setup. Keeping it simple yet effective.
Blownbillybob
Lance jus did mine got it today 7* at 23”
I’m going with the big sea star ram char-Lynn helm and cooler still have to get the pump
U going power or manual??
Nailhead
I would’ve thought power on that big Campbell
Manual is still has a very light steering sensation, even in the event of loss of power. It'd be great to go full overkill but with the Campbell that may it 65mph it's just not worth the cost times 3. I'll spend that elsewhere.
Blownbillybob
Don’t know if u have ur ram picked out yet I found this 1 on eBay that has mount tabs cast into it U could bolt it to a bracket which would be a lot stronger then the other way I’ve seen it done with a pinch clamp???
Food for thought???
Nailhead
Food for thought???
I wouldn't buy a used up Steering system but Thanks
Blownbillybob
Haha!!!
Didn’t mean buy it!!! The part #s for a new 1 are in the listing. And like I said it should jus bolt Wright up no custom brackets!!!
Blownbillybob
Found issues with all the newer O/B rams not good???
The piston on the rams are like a nylon/plastic they split and leak and no replacement parts are available??
Food for thought!!!
Nailhead
More work getting done, it was a total after thought to do this since the gel work was done but it’s Taken this long we might as well do it right. Joey and Vincente at D’Cucci boats are kicking ass on getting all the new driveline placed.
wettrthebettr
Nice , What is the green? is it a Gelcoat, Paint or what? I wanted to put a color in the center also, but didn't know what to use, And I was on a budget. Looking good.
Nailhead
More progress on Happy Hour, it sure is nice when someone really does the work they say they will in the time they estimate. D’Cucci boats nailed it!
Set a new strut, filled all the excess holes, drilled new shaft hole, reset v-drive, install drop thru strut and rudder support.
Nailhead
The original 42 year old trailer got some love too. Wanted to keep it as original as we could but with a modern braking system and lights. So far we are keeping the original wheels I took some Diet Coke and aluminum foil to clean the rust up
wettrthebettr
Set a new strut, filled all the excess holes, drilled new shaft hole, reset v-drive, install drop thru strut and rudder support. View attachment 824038 View attachment 824039 View attachment 824041 View attachment 824044 View attachment 824045 View attachment 824039 View attachment 824041
Looks Great, All your hard work is paying off, I have one advice about your Trim tabs, Don't forget to put them up before you pull the boat out of the water, or the plate will get bent from the end of the bunks. I for got once and now one tab plate has a mark. keep the updates coming.
Nailhead
We moved the boat back about 2” so the plates are just off the bunks. I have 2 new tabs that are 9x18 that I’d get rid of
First In
Updates it’s been awhile?
Is this work of art in the water yet?
How’s it run?
Love to see more pics of this beautiful Campbell
Thanks!
Nailhead
How’s it run?
Thanks!
It’s closer but had to stop since I was off work almost 6 months with this Covid crap. I’m down to getting a couple things buttoned up, need upholstery and wiring.
First In
Thank you for the update!
You’ve done an excellent job on this resto-project!
Can’t wait to see it on the water
