Hardcore Racing Garage sale SUNDAY 14th DEC at the 95 Speedway SWAP MEET in Havasu
Hardcore1
End of year clear out Garage sale, we need the space so its all gota go!
Mostly SBC, BBC, LS and BBF parts plus Blower carbs
Heres a list of some of the parts we will be taking but we have way too much to list everything!
its all going to be cheep so come check us out
BBC
Weiand Dual plane retangle port
Brodix Big Duke with fuel injection conversion(includes spacers for 11.1 deck blocks)
Dart Tunnel Ram EFI conversion complete with wire loom ECU and fuel pump
Merlin Oval port heads new SS valves Comp springs ect with Edelbrock RPM intake
4 Marine oil pans 10-14qt
Manley 6.535 rods
Valve covers 2 sets
Crower 1.8 Alum rockers
J.E. blower pistons 4.535 bore Used
Eagle cast 4.250 1 piece rear seal crank reground
Whipple blower intake polished
Various Hyd Roller and Solid roller cams
plus lots more!!!!
LS
Complete 416ci stroker LSX with New LS2 alum block Manley forged rotating, Trickflow CNC ported heads, all the beast parts! this engine is ready for Dyno and can be FI or carburated, estimated HP is 625+ this is going to the Dyno next week (see picture)
LS6 243 heads new valves and LS3 springs, valve job and surfaced, assembled raedy to install
LSX LS7 Racetec pistons 4.130 bore for 6.125 rod and 4.100 stroke NEW!
LS3 fabricated intake with fuel rails and throttle body (choice of drive by wire or cable type NEW
Alum 6 qt oil pan kit with pick up and gaskets NEW
Holley cathedral port intake with Brawlwr 750 hot rod black carb, intake is ported
plus lots more LS parts
Ford
351 Moroso truck pan
460 block bored and hone and square decked with Scat 4.150 stroker crank(make a 501ci)
Comp Cams solid roller NEW cam 272/278-110
Ford 302 stroker 347ci short block Scat rotating assembly with Mahle pistons(this is a freshed up short block but block is fresh machined and NEW crank, only rods and pistons have been used but comes with new Total Seal plasma moly rings and clevite bearings)
Carbs
2 sets of blower carbs(these need rebuilt so cheep)
Various Holley carbs
Bravo 1 XR rebuilt lower with new gears and bearing, has HD shafts and billet retainer
Bravo 1 Labbed 25" prop
Come check us out! look for the red Craftsman canopy with Hardcore racing Engines banner
Wheeler
Hardcore1
If you are interested in anything listed it can be seen at the shop in Havasu and your welcome to come by!
contact: call or text 928 310 5040 Andy
Wheeler
TTT
Hardcore1
what bore is the block and what has the crank been turned to? Is the crank installed in the block with bearings?
Bore's are +030 and set up for correct clearances for marine application, crank is fresh 020/020
Hardcore1
we can also supply the 6.800 rods and Racetec pistons if needed at a great price!
Fastdadtsmith
Just walked the swap meet. Didn't see all your goodies. I'm interested in your XR lower. I'll DM.
Hardcore1
Yes Fastdadsmith were very sorry to anybody that came out looking for us! we had trailer problems and by the time it was fixed it was too late!
give us a call 928 310 5040 or 909 851 8251
Hardcore1
As due to technical problems we unfortunately did not make the swap meet this weekend please see our post for Hardcore Racing & Marine engines ONLINE end of year garage sale
