StartTheClock
New Member
- Sep 15, 2020
- 3
- 0
Hawk Marine Power 500 hp Small block motor. It was set up for offshore racing but sat on the shelf and was eventually de-tuned for pleasure - but it still has all the good stuff. The only difference is the compression has been dropped to 9:1 so you can use pump gas. The motor is balanced and blueprinted. It includes the flywheel. I have a bravo belhousing and shift coupler if needed.
$ 6,500.
Stainless Marine Exhaust
Comp Solid Roller Cam
Manley Severe Duty 2.05 Valves
Comp Roller Springs 843-16
Clinch Shaft Rocker System
Carillo 6.0 Rods
Eagle 4130 Crank
CP Dish Pistons 9:00:1 Compression (Pump Gas)
Bill Mitchell Iron Heads. Ported to 1206 Gaskets
Hamburger Offshore Oil Pan
MSD Pro Billet Distributor
MSD 6A Boxes
External Mount Oil Filter
Aeroquip throughout.
Proform Center Holly 4150 850 CFM Carbs
Glenwood Cam Drive Water Pumps
Cams are .600 lift with 245 Duration @ .050
New Jeggs rolling motor racks
Comp Solid Roller Lifters
4.135 Bore and 3.5 Stroke
World Products Bowtie Block
MSD High Vibration Ignition.
9:1 Compression - pump gas.
400 CID and 500 hp on dyno
The motor could make 900 hp with 15 pounds of boost if you wanted.
AMAZING torque
Located @ Lake Norman, NC 28673.
Export and shipping available at buyer's cost.
310-890-5485
$ 6,500.
Carillo 6.0 Rods
Eagle 4130 Crank
MSD 6A Boxes
AMAZING torque
310-890-5485
