Thomas K
- Nov 30, 2021
- 181
- 411
I will look into that!You can change the min learn temp or disable it.
Are you talking about the no start in gear safety?There's a Air Conditioning feature in the Sniper software that proactively ups the idle to compensate for the extra load of the AC compressor. It's a one wire trigger that can potentially be tied into the safety switch in your shifter to come one when you put the boat in gear (might need to be used in conjunction with a "normally on" relay). Hope that helps!
He just needs to adjust his tune mo better.Are you talking about the no start in gear safety?
there is only so much "authority" the idle valve has....it can only bypass so much air. you need to find the sweet spot, with the engine warm and in neutral then open the butterfly to where it idles at target WITHOUT the idle valve. then reset the TPS to zero in the ECU. you should plug the idle valve port when doing this. once it idles at target mechanically, then reintroduce your IAC.Update. I did some other things to my boat as well. New ignition switch, new solenoids on my trim pump motor because my outdrive would not come up, even with the trailer switch. New engine control throttle shifter because my old quicksilver 3000 I really didn't like, and lubed my cables. Now I'm lake ready?
My wife and I did a shake down cruise last weekend to Lake Pleasant. She fired right up with no long crank times which was nice. When I tested the engine idle with the hose, it was very nice. Not so good on the water. My exhaust tips are below the water line when at idle. I think the added back pressure of the exhaust and actual load on the prop when in gear made for a rough idle and stalling when put into gear. My target rpm at idle was 750. I'm going to up it to 800-850 rpm. Hopefully that will fix it. Accelerating and on plane, she ran very smooth. Very responsive and she did not stumbling at any rpm. We cruised around for about 5 min. The engine temp was around 150 according to the handheld dash and so it was not into learn mode yet. I went to do a wot run to see if I could get the temp up a bit and the throttle handle went limp at 4400rpm. I thought the cable broke. After poking around a bit I found the problem.
The plastic retainer nut broke off the cable. The left cable in the photo is the throttle with the broken nut, the right is the shift cable. The shift cable nut has stress fractures in it as well. Not good.
So I disconnected the throttle cable at the motor and operated the throttle by hand while holding the engine hatch open a bit to get my arm in there while my wife drove. Haha kinda funny.
We tried to make the most of the day but it was getting really windy so we called it. My wife did great job getting back on the trailer considering the wind ,no throttle, and stalling. I pulled the plug and a ton of water came out of the bilge. Usually it is bone dry. Turns out the shift cable bellows has a big tear in it. Pretty disappointing because I replaced the bellows last year.
I was pleased with how the sniper operated. On the motor, I'm going to swap the location of the temp sensor for the efi with the dashboard temp sensor. The dash was reading around 180 while the efi 150. I hope that will make a difference to get the sniper into learn mode. Also up my target idle speed a bit.
I ordered all new cables and a bellows kit. Today I'm pulling the outdrive to do the lower shift cable and bellows.
2nd thisthere is only so much "authority" the idle valve has....it can only bypass so much air. you need to find the sweet spot, with the engine warm and in neutral then open the butterfly to where it idles at target WITHOUT the idle valve. then reset the TPS to zero in the ECU. you should plug the idle valve port when doing this. once it idles at target mechanically, then reintroduce your IAC.
before just assuming the IAC is faulty...its super easy to verify. pull it off the throttle body. find a rubber plug or equivalent to block the passage so air can not bypass the throttle.@DaveH Thanks. That is how I was adjusting the iac. We went for another shake down cruise yesterday. She stalled almost every time we put her into gear. Once she was in gear, she idled nice and ran wot at 4400rpm. I did mess with the cam setting. I have no idea what the cam is so I changed the settings in the handheld and what a difference. Ran like crap when I put it on mild/street cam. Stumbled and only could get a sluggish 3000rpm. Went back to the stock cam setting and that is where she likes it. I contacted Holley to see if I needed to do something different like the ac kick which @Streetmoto suggested. The Holley tech said I should not need that. Also asked about the min learn temp per @Blackmagic94. The tech did not give any info on how change it. But it would be nice to have it around 150. The tech asked me to give him some handheld info about the tps and the iac reading. The tech seems to think it is a faulty iac valve, so they are sending me a new one. Hopefully it will take care of the problem.
It is wired to the distributor. Before I was only getting 4000 at wot, that was with a 25p four blade. I have a 23p four blade on it now.It would seem the dash tach is more accurate, BUT, if so, 4400 at wot isnt right, which would indicate a lack of power or wrong prop selection. What rpm did you achieve prior to the sniper install?
Where does the sniper obtain rpm signal? From the distributor?
Maybe obtain a timing light with an rpm display to verify?
